ne
  • 118
Message 1 of 18
Keep loosing connection
repeats of these and loosing connection
14/06/2021 04:18:4criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/06/2021 04:18:4criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Neil B - Big Red Shed
Change is inevitable, except from a vending machine...
Andrew-G
  • 7.05K
  • 1.22K
  • 3.08K
Message 2 of 18
Re: Keep loosing connection
Often an easily resolved upstream noise or power issue.  Go back to the status page where you got those two entries from, and copy and paste in the same way all of the Network log, and then in separate posts the contents of the two other tabs titled Downstream and Upstream, and we can have a gander for obvious problems.
ne
  • 118
Message 3 of 18
DS
1 235000000 1.5 37 256 qam 13
2 139000000 4 37 256 qam 1
3 147000000 4 37 256 qam 2
4 155000000 3.9 37 256 qam 3
5 163000000 3.5 37 256 qam 4
6 171000000 3.5 37 256 qam 5
7 179000000 3.2 37 256 qam 6
8 187000000 3 37 256 qam 7
9 195000000 2.7 37 256 qam 8
10 203000000 2.2 37 256 qam 9
11 211000000 2 37 256 qam 10
12 219000000 1.7 37 256 qam 11
13 227000000 1.7 37 256 qam 12
14 243000000 1.4 37 256 qam 14
15 251000000 1 37 256 qam 15
16 259000000 0.7 37 256 qam 16
17 267000000 0.5 37 256 qam 17
18 275000000 0.2 37 256 qam 18
19 283000000 0 37 256 qam 19
20 291000000 0 37 256 qam 20
21 299000000 0.7 37 256 qam 21
22 307000000 1 37 256 qam 22
23 315000000 1.2 37 256 qam 23
24 323000000 1.5 37 256 qam 24
1 Locked 37.3 6876 1113
2 Locked 37.3 575634 62859
3 Locked 37.3 110390 48125
4 Locked 37.3 201370 19957
5 Locked 37.6 670111 54266
6 Locked 37.3 9533 2172
7 Locked 37.3 7949 1925
8 Locked 37.6 7620 1608
9 Locked 37.3 7572 1573
10 Locked 37.6 8404 1551
11 Locked 37.3 8291 1436
12 Locked 37.3 8448 1366
13 Locked 37.3 8037 1089
14 Locked 37.3 5740 1033
15 Locked 37.6 4805 999
16 Locked 37.3 4420 916
17 Locked 37.6 4553 829
18 Locked 37.3 4434 833
19 Locked 37.3 4563 843
20 Locked 37.6 4389 699
21 Locked 37.3 3565 687
22 Locked 37.3 2958 560
23 Locked 37.3 2637 656
24 Locked 37.6 2022 626
ne
  • 118
Message 4 of 18
US
1 32600000 46 5120 64 qam 5
2 39400000 46.5 5120 64 qam 4
3 46200000 46 5120 64 qam 3
4 53700000 46.5 5120 64 qam 2
Z92
  • 2.48K
  • 203
  • 392
Problem sorter
Message 5 of 18
When was the last time you rebooted your router?
Please do this to zero those number and then post back in a few hours after a few disconnections so we can see how quickly they count up again.
ne
  • 118
Message 6 of 18
will reboot when get back home.(rebooted yesterday 1pm)
the pic if it will post, graph, the red show each time it drops.ae86b1efe76252595f012a3d8364d83f3e43e4e9.png
Z92
  • 2.48K
  • 203
  • 392
Problem sorter
Message 7 of 18
If it was rebooted yesterday then you definitely have some noise on the line which would require further investigation. VM staff should check this post eventually and confirm the diagnosis and maybe even book an engineer for you (unless it's a area-wide issue, have you checked for known network faults?)
ne
  • 118
Message 8 of 18
no net faults.
Andrew-G
  • 7.05K
  • 1.22K
  • 3.08K
Message 9 of 18
I've flagged your post for staff to take a look and advise - could be an area fault, or unique to you connection.  If the latter they'll arrange a technician for you
ne
  • 118
Message 10 of 18
great ta.
hopefully they can also sort out the other modem fault in that its 2.4g wifi wont stay off. theyve admitted fault already. but its seems bad firmware.
It ws suggested i use modem mode, but thats no good, as i use the 5g, and my own 2.4g is wired at rear of house. theres enuf 2.4g around me, hence keeping hub 2.4 off. yet it wont stay off.
