Just got a Hub 4, power supply cable doesn't fit
Cheule
Up to speed
Hi all, as topic, I've just upgraded to Gig1 from the old M350. As a result, I've got the Hub 4.
Unfortunately, my excitement has turned to dust when I couldn't even plug in the new power supply to the Hub 4! It just will not fit and the port on the hub appears larger than the receptacle on the power supply side of things.
Help!
Virgin 1gbit - Superhub 4 modem mode --> RT-AC3200
19 REPLIES 19
Cheule
Up to speed
Both the Hub's power port and the power brick's connectors are female.
Anonymous
Not applicable
not sure what you mean the DC adapter is a male connection. Post a picture of what you have
Anonymous
Not applicable
not got the Hub4 myself but that looks about right
It's not, both connectors are female.
Anonymous
Not applicable
no the plug is male. the socket is female
From the pic it dose not look like it will fit.
Indeed, both receptacles are female, and the diameter of both are roughly the same.
MikeRobbo
It looks about right to me.
1 goes into 2,
3 goes into 4,
5 goes into 6.
Although it looks like there is a blob of Blu Tack in the hub socket.
hub-4-ps
