Issue setting up Hub 3.0
Hi, I've been trying to set up my new WiFi hub but for some reason after connecting to the WiFi it shows a connection error message, if i attempt to fix the issue on this screen nothing happens.
The router shows a white light at the bottom and green flashing arrows and has been left like this for 2 hours with no change. It has also been restarted multiple times which leads to the same issue
Thank you for any help.
  • 15.72K
  • 1.64K
  • 2.68K
Re: Issue setting up Hub 3.0
Did you follow the instructions to call in to "activate" it on your account?
Inside of the instruction booklet that came with it, it says that new boxes will automatically activate when correctly installed and did not provide a number to call. I did try calling in on the ordinary support number but there was no response probably due to covid delays.
If there is a specific number to call and you know it please let me know
Thank you
  • 15.72K
  • 1.64K
  • 2.68K
You have 3 options to activate VM equipment – I’d try all 3!
1) The equipment activation number is... 0800 953 9500 - calling at 08.00 gives the best chance of getting through but try others too
2) Or, due to loss of support staff a text service has been set up - send details of your issue and include your account number to - 07533 051809 - responses are much slower though
3) A VM person should respond on here when they pick it up.
  • 94
  • 27
  • 31
Was this resolved for you?
Dean  M
Unfortunately not yet, I tried to call in and message but got no response after a couple hours of waiting. I was going to try again later
