on 09-11-2020 16:22
I have recently upgraded from 500MB with Super Hub 3 to 1 GB with Super Hub 4 but haven't received it yet.
I currently use device filtering by MAC address to ensure only approved devices are connected to my home network. In total I have about 13 devices. Is there a way to transfer this settings from the old hub to the new one to save me the pain of adding all Mac addressed again and renaming them?
Also, I need to make sure my current I.P address stays the same; to avoid being blocked and having to white-list my network for a number of services I am using at the moment. Is it possible to keep my I.P. address when I switch from Super Hub 3 to Super Hub 4?
Thanks in advance
MAQ
Answered! Go to Answer
on 09-11-2020 16:32
There is a Backup function in the Hub 3 settings.
A friend of mine tried to use the Backup in a replacement Hub 3 but it wouldn't accept the file.
It may work with the Hub 4 but I have my doubts.
on 09-11-2020 16:34
The Virgin Media IP will change.
on 09-11-2020 16:32
on 09-11-2020 16:34
on 09-11-2020 16:37
09-11-2020 18:37 - edited 09-11-2020 18:39
By default it's not possible to load a configuration from a hub3 into a hub4. It may be possible in the future however.
Your external IP address is dynamic and can change at any time. It rarely does however.
on 09-11-2020 20:08
@Z92 wrote:By default it's not possible to load a configuration from a hub3 into a hub4. It may be possible in the future however.
It will change with the new hardware Hub 4.
