Malcolmw1
Internal white connection box
Is it possible to change the VM internal white connection box for a different one such as a brushed chrome outlet?  Also can the V6 cable and router cable be installed to the same socket?
  • 3.2K
  • 251
  • 700
Re: Internal white connection box
VM sockets are white, they do not supply another choice.  If you want brushed chrome, you can source your own enclosure that will house all the relevant cables.   If you want both cables in the same enclosure, then VM will need to supply a splitter for this at a £99 non fault call out fee.
Akua_A
  • 1.24K
  • 31
  • 80
Hi @Malcolmw1,
Welcome to our community forums and thank you for your first post.
In regards to your Internal white connection box enquiry, was the great advice given by @Adduxi useful? Do you require any further help regarding this?
Please get back to us when you can.
Akua_A
