Intermittent drop outs low speed
Dolgan
Hi all
I am posting here as I am not having much luck with customer service on the phone. For the last 4 weeks or so my broadband speeds have been slow with intermittent drop outs. i have the 1200 Mbps service and intially i was getting a wired connection speed of 80 or so with intermittent drop outs. currently i am getting 300 - 400 wired, but its dropping out for 20 - 30 seconds at a time every few hours. To be honest the drop outs are more irritating than the slower speeds.
My setup is Virgin hub in modem mode with TP link Deco S4 doing wifi and DHCP.
I have spoken to customer services repeatedly and they tell me theres an issue in the area that affects 35% of customers. Ive asked for an idea of when this issue will be fixed because its been 4 weeks now but then they start offering me Wifi Boosters. On their advice I have reset the modem and tried connecting to it directly without the Deco but the results are the same. Is anyone able to advise me what to try next?
Any help much appreciated
Matt
29 REPLIES 29
Dolgan
I have some details form the router status page if it helps
Cable Modem Status
Item
Status
Comments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview
Downstream
Upstream
DOCSIS 3.0 channels
31
5
DOCSIS 3.1 channels
1
0
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
25
331000000
9.9
37.4
QAM256
25
18
275000000
8.3
35.6
QAM256
18
19
283000000
8.2
36.6
QAM256
19
20
291000000
8.1
36.6
QAM256
20
21
299000000
8.6
36.6
QAM256
21
22
307000000
9.4
36.6
QAM256
22
23
315000000
9.7
36.4
QAM256
23
24
323000000
9.5
36.6
QAM256
24
26
339000000
10.5
37.6
QAM256
26
27
347000000
11
37.4
QAM256
27
28
355000000
10.9
37.4
QAM256
28
29
363000000
10.9
37.4
QAM256
29
30
371000000
10.9
37.4
QAM256
30
31
379000000
11
37.4
QAM256
31
32
387000000
10.9
37.6
QAM256
32
33
395000000
10.5
37.6
QAM256
33
34
403000000
10
37.4
QAM256
34
35
411000000
10.1
37.6
QAM256
35
36
419000000
10.5
37.6
QAM256
36
37
427000000
10.9
37.6
QAM256
37
38
435000000
11.2
37.4
QAM256
38
39
443000000
11.7
37.6
QAM256
39
40
451000000
11.7
37.6
QAM256
40
41
459000000
11.5
37.6
QAM256
41
42
467000000
11.8
37.4
QAM256
42
43
475000000
12.1
37.6
QAM256
43
44
483000000
12.7
37.6
QAM256
44
45
491000000
13.2
37.6
QAM256
45
46
499000000
13.7
38.6
QAM256
46
47
507000000
13.9
39
QAM256
47
48
515000000
14.1
38.6
QAM256
48
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
25
Locked
37.355988
1
0
18
Locked
35.595078
2
0
19
Locked
36.609653
0
0
20
Locked
36.609653
0
0
21
Locked
36.609653
1
0
22
Locked
36.609653
1
0
23
Locked
36.386890
3
0
24
Locked
36.609653
1
0
26
Locked
37.636276
0
0
27
Locked
37.355988
4
0
28
Locked
37.355988
2
0
29
Locked
37.355988
5
0
30
Locked
37.355988
6
0
31
Locked
37.355988
8
0
32
Locked
37.636276
7
0
33
Locked
37.636276
9
0
34
Locked
37.355988
12
0
35
Locked
37.636276
21
0
36
Locked
37.636276
14
0
37
Locked
37.636276
22
0
38
Locked
37.355988
28
0
39
Locked
37.636276
20
0
40
Locked
37.636276
32
0
41
Locked
37.636276
40
0
42
Locked
37.355988
47
0
43
Locked
37.636276
48
0
44
Locked
37.636276
38
0
45
Locked
37.636276
42
0
46
Locked
38.605377
25
0
47
Locked
38.983261
31
0
48
Locked
38.605377
32
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
159
96
4K
1880
QAM4096
759
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
159
Locked
42
16.1
250511981
1445
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
23600000
40
5120 KSym/sec
32QAM
13
2
30100000
40
5120 KSym/sec
64QAM
12
3
36600000
39
5120 KSym/sec
64QAM
11
4
43100000
39.5
5120 KSym/sec
64QAM
10
5
49600000
39.5
5120 KSym/sec
64QAM
9
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_STDMA
0
0
5
0
2
US_TYPE_STDMA
0
0
0
0
3
US_TYPE_STDMA
0
0
0
0
4
US_TYPE_STDMA
0
0
0
0
5
US_TYPE_STDMA
0
0
0
0
jpeg1
There are problems with both your downstream and upstream connections which will need the attention of a technician to resolve. A pod will not fix these.
Dolgan
Thanks, so i need a technician to visit ?
They dont want to send one as they are again saying that the problem affects 35% of people in my area and will be resolved ASAP
When I press them saying this has been going on for 4 weeks they say there is no update and no ETA for a fix, that cant be right can it ?
jpeg1
You do, but unfortunately they won't send one if there is a known local issue.
That's just the way they work.
Hi Dolgan,
Thank you for reaching out to us in our community and welcome, sorry to hear you have been facing an intermittent connection, I wasn't able to locate you on our system with the details we have for you, so I can help further I will send you an invite into a private chat, once received click on the purple envelope to accept.
Paul.
Dolgan
I have just replied to Paul so I will see what we can do, my internet has gotten worse with prolonged drop outs affecting me and my neighbours then they are 'fixed' only to happen again a few days later
Hi Dolgan,
Thank you for joining me in a private chat and for the details, as you have advised yourself and neighbours are facing the same issues, I have had a look and can see there is an SNR (Signal to Noise Ratio) this is usually caused by a damaged or exposed cable giving noise on the network, this was raised on 28/11/22, I understand you have been facing issues before this I can only assume this has been present earlier but not picked up.
You might find that your Virgin Fibre, Voice and Virgin TV services are intermittent, with the picture freezing or disappearing now and then. We are sorry and our engineers are working hard to resolve this for you.
You might find that your Virgin Fibre, Voice and Virgin TV services are intermittent, with the picture freezing or disappearing now and then. We are sorry and our engineers are working hard to resolve this for you and your neighbours, the estimated fix is today @ 18:00, you can sign up for updates Via your Online account.
Paul.
Dolgan
Hi Paul
Thanks for your reply
Whatever they did the other day hasnt helped me with the constant drop outs, the website now shows no area faults but when you test the hub it says there are issues in the area.
This has been over 6 weeks now, when I call customer support they wont tell me anything other than its being worked on
I dont know what to do next other than try to cancel or something, its incredibly frustating. Even if i could get an engineer out to help move things along maybe something would happen, clearly at the moment its just sitting in limbo
thanks
Matt
Hi Matt,
Thank you for reaching back out, really sorry to see you are still facing issues after 6 weeks of an intermittent connection and are now thinking of leaving.
I have had another look your end and there is a short term connection issues showing, these are usually corrected with 24 hours, please check all your internal connections are hand tight, this includes on all equipment and splitters coming in, once done unplug the Router from the power, leave 2 to 3 minutes then plug back in.
Paul.
