The 1Gig connection I have has been suffering from periodic intermittent packet loss for several months now. I set up a BQM and updated it with my current IP address last night at around 10pm. The BQM graph looks like this:
(Prior to 10pm the BQM was monitoring someone else's IP address.)
I've tried resetting the hub several times and I've also tried putting the hub in modem mode but the problem persists. The packet loss seems to come and go with no discernible (to me at least) pattern. There might be no packet loss during the day after 14:00 until 22:00 and then intermittent packet loss overnight or no packet loss overnight and all through the day.
Stats from the hub as of 10pm last night shortly after I disconnected the modem cables and reconnected it to make sure it was firmly seated:
Cable Modem Status
Item Status Comments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel Overview Downstream Upstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
3.0 Downstream channels
25 330750000 7.5 40.4 QAM256 25
9 202750000 8 40.4 QAM256 9
10 210750000 7.9 40.4 QAM256 10
11 218750000 7.7 40.4 QAM256 11
12 226750000 7.4 39 QAM256 12
13 234750000 7.1 39 QAM256 13
14 242750000 7.3 39 QAM256 14
15 250750000 7.7 39 QAM256 15
16 258750000 7.9 38.6 QAM256 16
17 266750000 7.9 38.6 QAM256 17
18 274750000 7.8 38.6 QAM256 18
19 282750000 7.9 38.6 QAM256 19
20 290750000 7.9 38.6 QAM256 20
21 298750000 8.1 38.6 QAM256 21
22 306750000 7.7 40.4 QAM256 22
23 314750000 7.4 40.4 QAM256 23
24 322750000 7.5 40.4 QAM256 24
26 370750000 6.5 39 QAM256 26
27 378750000 6.6 39 QAM256 27
28 386750000 6.7 38.6 QAM256 28
29 394750000 6.9 38.6 QAM256 29
30 402750000 7 39 QAM256 30
31 410750000 6.9 39 QAM256 31
32 418750000 6.8 38.6 QAM256 32
33 426750000 6.7 40.4 QAM256 33
34 434750000 6.5 40.4 QAM256 34
35 442750000 6.7 40.4 QAM256 35
36 450750000 6.5 40.4 QAM256 36
37 458750000 6.5 40.4 QAM256 37
38 466750000 6.6 40.4 QAM256 38
39 474750000 6.5 40.4 QAM256 39
25 Locked 40.366287 0 0
9 Locked 40.366287 0 0
10 Locked 40.366287 0 0
11 Locked 40.366287 0 0
12 Locked 38.983261 0 0
13 Locked 38.983261 0 0
14 Locked 38.983261 0 0
15 Locked 38.983261 0 0
16 Locked 38.605377 0 0
17 Locked 38.605377 0 0
18 Locked 38.605377 0 0
19 Locked 38.605377 0 0
20 Locked 38.605377 0 0
21 Locked 38.605377 0 0
22 Locked 40.366287 0 0
23 Locked 40.366287 0 0
24 Locked 40.366287 0 0
26 Locked 38.983261 0 0
27 Locked 38.983261 0 0
28 Locked 38.605377 0 0
29 Locked 38.605377 0 0
30 Locked 38.983261 0 0
31 Locked 38.983261 0 0
32 Locked 38.605377 0 0
33 Locked 40.366287 0 0
34 Locked 40.366287 0 0
35 Locked 40.366287 0 0
36 Locked 40.366287 0 0
37 Locked 40.366287 0 0
38 Locked 40.366287 0 0
39 Locked 40.366287 0 0
3.1 Downstream channels
159 96 4K 1880 QAM256 759
159 Locked 27 2.6 2041022 56034
3.0 Upstream channels
1 46200000 42.5 5120 KSym/sec 64QAM 3
2 25800000 40 5120 KSym/sec 16QAM 6
3 32600000 41 5120 KSym/sec 64QAM 5
4 39400000 42 5120 KSym/sec 64QAM 4
1 US_TYPE_STDMA 0 0 0 0
2 US_TYPE_STDMA 0 0 0 0
3 US_TYPE_STDMA 0 0 0 0
4 US_TYPE_STDMA 0 0 0 0
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cxv9873254k;fg87dsfd;kfoA
SFID
598
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
597
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
Is there anything else I should test?
