Insulator Cable not fitting in box on wall
IMRobertson1944
Got the quickfire kit, but the insulator cBle will not fit, do I need an engineer to look at the box
1 ACCEPTED SOLUTION
Accepted Solutions
mpmc
Superfast
Someone from VM will answer in a few days (up to a week or more sometimes - they're very busy on here). But if you can provide a picture of what you do have, please do. Other members on here may be able to assist.
TV, Phone + EBUL v3, and Broadband using the Hub 3.0 in modem mode, with a Newifi D2 running Openwrt (FTTP/RFoG).
6 REPLIES 6
mpmc
Superfast
  • Box has been on wall for 2 years plus
  • Insulator cable just falls out when trying to connect it
Take off the cover and check the cable is secure and not loose on the wall.  You should be able to push the cable onto the screw fitting.
Hi IMRobertson1944,
Welcome and thank you for posting 🙂
I am very sorry to hear you are having issues with the installation of your quickstart kit.
Can we please just check if you have been able to follow Adduxi's advised in order to get this connected?
If not, please do let us know and we will be happy to assist further.
Nat
It's now fixed, engineer fixed the problem  it was an old connector
Hi IMRobertson1944 - thanks for coming back to the thread with the update. I am glad everything is fixed for you 🙂 is there anything else we can help with?
If not, have a wonderful day and drop us a post on here should you ever need us.
Best,
John_GS
