  • 10
Message 1 of 18
Installation of Hub 3 major issues
I have bought and installed the new Hub 3 router correctly, however the router does not receive  internet.
I have tried all the usual unplugging and restarting, but this is not the issue. On the hub there is a green wifi light and a flashing green bar at the bottom.
I have activated the account but nothing has happened.
I have been desperately trying to contact someone at Virgin as nothing is working. Please help, I thought the quick setup would be easy. So far it has not been quick or easy and the customer support service has been terrible.
Please may someone assist me.
  • 15.25K
  • 1.2K
  • 3.58K
Message 2 of 18
Re: Installation of Hub 3 major issues
just to be sure - you say you have bought the hub3 - is that from VM - i assume so as you then mention quick start - if you have got the hub from anywhere else it will not work
assuming its from VM then try the activation line again - if it still does not work you likely need a tech to sort it as it would look like a cable fault - maybe been cut or damaged or not connected in the cabinet
____________________
Tony
  • 10
Message 3 of 18
Hi Tony,
Yes it's a Hub 3 from Virgin Media.
I think there is a fault so will require a tech.
Many thanks,
Elliot
  • 10
Message 4 of 18
Hi Tony,
Many thanks,
Elliot
  • 12.13K
  • 942
  • 1.55K
Message 5 of 18
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
  • 10
Message 6 of 18
Hi Mike,
We can't wait any longer as we've had no internet for 4 days now. What number do I call to get this sorted?
The number I have been told to call (0345 454 1111) doesn't work as I waited twice on the phone today for over 35 minutes each time with no response..
Many thanks,
Elliot
  • 15.25K
  • 1.2K
  • 3.58K
Message 7 of 18
thats the number - 8 in the morning is a good time - quick install comes with risks but lets look at what you have - is there just the one box in the house - sometimes it can just be a cable - start with the outside box and follow any cables that go into the house
Tony
  • 10
Message 8 of 18
Hi Tony,
Yes it is just the one box. I'll try my luck at 8 am.
Many thanks,
Elliot
  • 10
Message 9 of 18
Hi Tony,
I've been on the phone waiting since 8 AM and still no luck....
Why is this so hard to fix?
  • 10
Message 10 of 18
45 minutes now...
This is a ridicules service. All options send you in a loop and no options are actually useful for getting this fixed. Please we need assistance today.
