Wilson82
Just joined
IMO Q2 plus mobile stuck on ‘phone is starting’
When I start my phone it says ‘phone is starting..’ but has been like this for over an hour. Have taken out battery and sun and restarted but no help
DJ_Shadow1966
  • 7.1K
  • 1.36K
  • 2.01K
Re: IMO Q2 plus mobile stuck on ‘phone is starting’
Hello
Have a look at https://www.devicesfaq.com/en/reset/imo-q2 under the section "Restore with hard reset or Recovery mode IMO Q2" as it sounds like there is a software problem, beaware that doing this will reset everything on the phone.
Regards Mike
