I received my broadband kit yesterday but I need the help of an engineer please
Faderera2610
I don't have the virgin media socket in my house, just like other similar issues I've read on this forum. Please I need an Engineer as I need internet for my work, I am so frustrated right now. Please help out
1 REPLY 1
You can also check for a loose cable as not all properties have a socket. Look outside for a brown or grey VM box on the wall and trace the cable to the inside. If it is a loose cable only, you will need one of these to connect the Quickstart cable. https://www.diy.com/departments/slx-f-type-satellite-cable-coupler/5028422001905_BQ.prd
Try calling the pre-installs team on 0800 052 1734 8AM- 9PM Monday - Friday or 8AM-6PM Saturday and Sunday if you can't find the cable.
