you say the hub3 works fine - lets just be clear
you have connected the hub4 and activated it and you get a red light
you then put the hub3 back on the connection and it works fine
if thats correct then the hub4 is not activated whatever CS may tell you
so if thats it - 0800 953 9500
____________________
Tony.
Sacked VIP
