djpadrecito
  • 6
Message 1 of 13
Hub4 conectivity issues
Hello !
I have upgraded to 1 Gb speed and received yesterday my hub4.
tried to connect it today as per instructions + activated it too.
initially, it did not want to connect to wifi, then after several reboots and hard reset, it did, but the speed is low, not loading the pages properly, fluctuating, dropping and then coming back again.
My ubiquiti amplifi is not working now trough it Nd i need this to work, as i work from home.
it did well with hub3, now if i connect hub3 back, it will not work.
tried to call vm, but they are closed, i do not know the opening hours…
i have access to router page, unfortunately i would not know what to select there.
any ideas?
looks like a faulty hub4 ?
thanks
  • 12.83K
  • 998
  • 2.56K
Message 2 of 13
Re: Hub4 conectivity issues
You need to go to the settings and put the hub into modem mode.
djpadrecito
  • 6
Message 3 of 13
Will that solve the conectivity issue?
i do not have my own private router to replace vm hub,  i use a mesh and the virgin hub
  • 12.83K
  • 998
  • 2.56K
Message 4 of 13
Who makes the mesh you use? Most mesh master units will operate in two modes, router mode or bridge mode.
djpadrecito
  • 6
Message 5 of 13
I have an Ubiquiti Amplifi with 3 extra acces points which is  now not working after trying to connect it to the hub 4 (hub 4 constantly dropping connection)
  • 12.83K
  • 998
  • 2.56K
Message 6 of 13
The Ubiquiti Amplifi is definitely a router, you must have the hub4 in modem mode.
djpadrecito
  • 6
Message 7 of 13
Ubiquiti Amplifi 4-Ports Home... https://www.amazon.co.uk/dp/B01L9O08PW?ref=ppx_pop_mob_ap_share
this is what i have got!
Do i have to do put the hub into modem mode?
i have an eng scheduled now for tomorrow AM, as the were unable to fix anything over the phone.
  • 12.83K
  • 998
  • 2.56K
Message 8 of 13
Manual:
https://amplifi.com/docs/AmpliFi_HD_QSG.pdf
How to put a VM hub into modem mode, not published by VM probably because they don’t want you to use it and use their pods.
1) Access your hub on 192.168.0.1, sign on and put it into modem mode. On the Hub3 the bottom LED will change to magenta. Best done from a wired connection.
2) Turn off the hub and disconnect any Ethernet cables
3) Fully initialise your own router and make sure the WAN port is set to DHCP
4) Connect your router to the VM hub with an Ethernet cable, Cat5e or Cat6, any higher specification is a waste of money
5) Turn on the VM hub.
6) You should now be able to access the internet and the hub will now be on 192.168.100.1
djpadrecito
  • 6
Message 9 of 13
Works with hub4 too?
  • 12.83K
  • 998
  • 2.56K
Message 10 of 13
Yes, just that the hub4 does not show when it's in modem mode.
