kingsy11
Message 1 of 5
Hub red light
Hi, our virgin hub is on a permanent red light. I have tried on/off restarts and pinhole reset but all with same result. Red light. Any advice welcome
kingsy11
Tags (1)
Graham_A
  • 19.34K
  • 2.75K
  • 8.09K
Message 2 of 5
Re: Hub red light
kingsy11
What version of hub do you have?
If a Hub3 the red light usually signifies overheating.
________________________________
Graham
I'm a Very Insightful Person, I'm here to share knowledge, I don't work for Virgin Media, I'm a VM customer. There are no guarantees that my advice will work. Learn more
Zoie_P
  • 5.28K
  • 218
  • 409
Message 3 of 5
Re: Hub red light
Hi Kingsy,
Thank you for your post and welcome to our forums 😊
I am sorry you have been having issues with your hub and can see from our systems you need a tech to replace this for you.
I will pop you over a PM and we can get this looked into for you ASAP, keep an eye out for the little envelope 📩.
Zoie
kingsy11
Message 4 of 5
Re: Hub red light
Hi there.
Thanks for responding. it’s a hub 3, but not hot at all.
Even after being turned off for a long period of time and then turned back on, the red light remains. Kingsy.
Zoie_P
  • 5.28K
  • 218
  • 409
Message 5 of 5
Re: Hub red light
Hi Kingsy11,
Thank you for messaging me 🙌
Glad we could get this booked for you, hope all goes well with your visit if you need to cancel or change or even need to double check the time of the appointment you can do so 👉 here.
Zoie
