Kerno900
  • 8
Hub power flashing green
So my hub has decided to stop working we have no Internet or TV as of yesterday and still the same today
Its a hub 3
Flashing green power light
Flashing green Internet access light flashing
Solid green WiFi light showing
Reset the router already and done the pin hole too
Virgin said to check all cables and they are all good too
Anyhelp would be amazing
Tags (1)
Danny08
  • 51
  • 5
Re: Hub power flashing green
Hello,
You should contact the Customer Services, the sounds of this would need a tech to come out check your connections and services. The customer services should able arrange this for you.
Call : 0345 454 1111
Just give our Customer Care team a call on 150 from your Virgin Media Phone or from your Mobile, call 0345 454 1111 – Select option 2.
tehwolf
  • 1.57K
  • 253
  • 379
Superfast
It's worth calling the automated service status line which will let you know of any area issues that may be affecting you - 0800 561 0061
