  • 5
Message 1 of 9
Hub cable not compatible with Virgin wall socket
Hi, I’m unable to follow the set up instructions of my Virgin broadband Hub. The existing Virgin wall socket has a cable dangling out, labelled CON 3.9. This is not compatible with the wall socket end of the white cable provided with the router. The CON 3.9 cable has a spinning nut at the end. Has anyone encountered this issue, is an engineer visit required?
Many thanks!
  • 30.29K
  • 1.51K
  • 5.26K
Message 2 of 9
Re: Hub cable not compatible with Virgin wall socket
can you post a picture of the cable
  • 5
Message 3 of 9
Link
  • 30.29K
  • 1.51K
  • 5.26K
Message 4 of 9
it looks like the isolator has been removed from the wall box. you'll most likely need an engineer out to install a new one.
you can try and call in or wait a few days for staff here to get to the post and they can arrange one
  • 14.83K
  • 1.16K
  • 3.46K
Message 5 of 9
as a quick/permanent fix have a look in your local B & Q or screwfix or the like
https://www.diy.com/departments/tristar-data-cable-coupler/571706_BQ.prd
the input needs an isolator but you should have got that in the quickstart kit as the cable supplied
connect it up and activate the hub and hopefully it will work - if it does you can still book a tech to make a better job of it - if it does not work as quickstarts sometimes do not then you need a tech regardless
____________________
Tony
  • 5
Message 6 of 9
Thank you, good to know that’s the issue.
  • 30.29K
  • 1.51K
  • 5.26K
Message 7 of 9
What he said 😛
  • 5
Message 8 of 9
Many thanks, I’ll give that a try.
  • 5
Message 9 of 9
Un update in case anyone else has the same issue: the B&Q cable coupler worked fine, was able to connect.
Thanks again.
