on 31-10-2021 14:58
Hi. I've been trying to login web interface on 198.168.0.1 using the password provided underside of my device, but the given password does not work. I tried to reset the device by holding the reset button with several methods I found in the forums (holding it for over 60 seconds or holding reset button for 15 seconds, then waiting 5 seconds and repeating that 3 times) but I am still getting "The password you entered is incorrect." message when logging in. What is the correct way to hard reset Hub 5 to its defaults?
Many thanks,
Burak
Answered! Go to Answer
on 31-10-2021 15:58
One observation on the password - is the third character a c? It looks like an o but it is narrower than the o in Password.
on 31-10-2021 15:15
The address will be 192.168.0.1
on 31-10-2021 15:17
Oops made a typo there when writing my question. I've been using 192.168.0.1 already.
on 31-10-2021 15:19
… and you are sure you are using the Settings password and not the WiFi password?
on 31-10-2021 15:37
Yes, here's the picture of label underside my router. I tried using the password with the red underline.
on 31-10-2021 15:54
Checked for case sensitive?
on 31-10-2021 15:58
Yep, I did. I've also tried all uppercase and all lowercase as well but no chance.
on 31-10-2021 15:58
on 31-10-2021 16:08
Haha, that's a spot on observation Ernie_C, it was the letter "c" from the beginning! I totaly missed that, thanks a lot for your help.
31-10-2021 18:52 - edited 31-10-2021 18:53
Ironic really that the 'o' in 'Sagemcom' is missing a section... (It is how their logo is designed!)
