Dazdc0145
Settling in
Message 1 of 10
Hub 5 problems
I received my hub 5 today and hooked it up I first got a solid white light then a flashing white light I now have a flashing slow blue light with no Internet. I have currently been waiting 20 mins with no change..
Any help on what could be happening would be great.
Thanks darren
Dazdc0145
Settling in
Message 2 of 10
Re: Hub 5 problems
Just to add I put the hub 3 back in and worked problems
jem101
  • 4.24K
  • 436
  • 1.81K
Community elder
Message 3 of 10
Re: Hub 5 problems
If the hub 3 still worked then it means that the 5 hasn’t been provisioned or activated on your account yet. Was there any instructions included with the 5 about calling a certain number?
Dazdc0145
Settling in
Message 4 of 10
Re: Hub 5 problems
In the booklet it says if after 30 mins call an 0800 number
DavidJWalker
  • 781
  • 53
  • 118
Well-informed
Message 5 of 10
Re: Hub 5 problems
now all hub 5 actice when you replace it and make sure the connectioned it right there is 0800 953 9500 thats if pass 10 mins
My Broadband Ping - Virgin Media 350MB
Using Ultimate Volt bundle
Just another VM user trying to help out so my answers may be wrong. If you do like my answer please mark it as helpful; it may help others
Dazdc0145
Settling in
Message 6 of 10
Re: Hub 5 problems
Thanks phoned the number and activated it
Emilczak
Message 7 of 10
Re: Hub 5 problems
I have the same problem, the lamp is blinking blue all the time and there is no internet. How did you handle it?
kannanni
  • 82
  • 12
Message 8 of 10
Re: Hub 5 problems
Same thing here flashing blue light. Their system said it’s activated. Gave up and put my  hub 3 back, had to call them and activate my hub 3.
interested to see if anyone has any suggestions In how to activate the hub 5?
Emilczak
Message 9 of 10
Re: Hub 5 problems
I called virgin media and on Monday May send a fitter to connect Hub5 to me, so I'm waiting for now
Paulina_Z
  • 4.32K
  • 160
  • 327
Message 10 of 10
Re: Hub 5 problems
Hi @Emilczak,
Welcome to our Community Forums! Thank you for your first post, and I'm sorry to hear that you're experiencing the same issue as @Dazdc0145. I can see that you have contacted our team about this issue already and are waiting for a technician appointment.
Please keep us updated on how you get on and if you need any further support going forward. We'll be happy to help.
Thank you.
Paulina_Z
