S7yleex
Hub 5 not working blue flashing light
So i got the new hub5 today set it up fine but have a blue flashing light i called up 5 times yesterday (because they kept hanging up) to be told i had to wait for a call in 3 hours that never happened today the same issue i explained i work from home and need the Internet and asked if i can use my old hub3 and they told me no
So what do i do
carl_pearce
  • 1.42K
  • 91
  • 313
Knows their stuff
Re: Hub 5 not working blue flashing light
Tom_W1
  • 2.86K
  • 154
  • 285
Hi @S7yleex, thanks for your post and I'm sorry you've got problems with your Hub 5.
Based on what I can see on your account, your Hub 3 is the active Hub on your account at the moment - it looks like this is because we were able to reactivate this for you while we sorted the Hub 5 problem. Early indications from your account appear the fault's been fixed!
I'm going to pop you a PM just so you can confirm a couple of security account details and we can arrange a time where I can try and activate your Hub 5 that's suitable for you.
Tom_W
