what exactly are you doing - i assume you are an existing customer that has an older [better] hub and have convinced yourself or VM have convenience you the 5 is better
that apart have you activated the 5 - if not your old hub will be the one on the account so will still be working
ring 0800 953 9500 to activate the 5 - dont send your old hub back you might just find [as many others] that the 5 is not all its cracked up to be
____________________
Tony.
Sacked VIP
