Hub 5 install problems
hanitakashi
Hi all, I'm trying to install a hub 5 but it is flashing green and has been for hours now.
When I check on my meter it is showing downstream and upstream are all in spec however I can only see 4 upstream channels rather than 5, is this normal? Downstream is showing 32 channels. I've checked all cabling and f connectors and they all seem in good condition so I'm running out of ideas on why it won't give me any service.
It's a FTTP house if that helps anyone kind enough to answer!
2 REPLIES 2
Legend
4 upstream channels is common, that is what we have on an RFoG / FTTP connection.
Have you tried a call to the Hub activation number 0800 953 9500  ?
Matthew_ML
Hey hantiaskashi, thank you for reaching out and a warm welcome to the community, I am sorry to hear this.
This could mean there is a update going to it which would make sense.
How has it been still flashing? Cheers
Matt - Forum Team
New around here?
