Hub 5, deco, modem mode. Help.
VickiB2010
Dialled in
Hi all.
I have just upgraded to the hub 5. My last hub I had deco M5 connected to previous hub which was in modem mode.
I have disconnected the old hub and connected the new hub 5.
here’s where I’m a bit confused. The hub 5 is set up and running but it looks like it’s automatically connected to the deco as my WiFi is connected through my deco which is named ‘Vicky’ the new hub is ‘VM***’. All my gadgets, including tv have set up through deco ‘Vicky’.
The hub 5 isn’t on modem mode.
What have I missed here?? I thought the deco only worked on the hub if the hub was in modem mode??
5 REPLIES 5
So you should change to modem mode VM don't support what ever way you go with a deco so might as well go with the way you should go.
DO NOT RAISE DUPLICATE POSTS already responded on your original post.
Oh I do apologies to you.
Thank you, I will do it tomorrow.
Kath_F
Hi VickiB2010,
Whilst the router will work when the hub is in normal mode, we recommend you pop it into modem mode to ensure there is no WiFi interference between the hub and router.
I can see Tudor has given you some step by step instructions here
If you have any further issues, pop back and let us know.
Kath_F
