16-10-2022 20:46 - edited 16-10-2022 20:52
Recently received a Hub 5 to replace my Hub 3. All swapped and activated fine yesterday (Saturday 15th October). I noticed that the green status light is constantly blinking which seems to indicate a potential software update in progress state, based on reading other posts here. However the light has been like this for over 24 hours. I have tried rebooting but it still does this after a restart.
My observations:
1. This message is in the networks logs at intervals
16-10-2022 20:34:33 | error | SW upgrade Failed before download -TFTP Max Retry Exceeded |
2. Telephony is shown as disabled in the web interface but it appears to be working as ringing out from the my phone line works.
The telephony disabled being shown despite the landline working, is possibly a firmware bug?
The software version my Hub 5 has is: LG-RDK_2.23.16-2106.14. I'm not sure if there's a newer firmware out in the wild. It would seem my Hub 5 isn't able to contact the firmware update endpoint, which is why the log messages and the green flashing light constantly. I am running the Hub 5 in modem mode. It was in router mode for the activation but I changed it to modem mode immediately after.
Has anyone experienced similar issues?
James
on 17-10-2022 13:22
F.Y.I. My new HUB 5 is
on 17-10-2022 15:04
There are users reporting the firmware update green flashing lights here. Some are working after a Hub reboot, others are reporting several days before the flashing stops.
In modem mode the light should be a solid green.
on 17-10-2022 18:54
Thanks for the info. It does appear there is a newer firmware version in the wild then.
I've looked at the network logs and it seems that the Hub 5 is trying to reach some form of update server/location but failing before giving up. I assume there's a out of hours schedule between 1 AM and 5 AM when it automatically retries.
17-10-2022 05:04:43 | error | SW upgrade Failed before download -TFTP Max Retry Exceeded |
17-10-2022 05:04:31 | notice | SW Download INIT - Via NMS |
17-10-2022 04:04:44 | error | SW upgrade Failed before download -TFTP Max Retry Exceeded |
17-10-2022 04:04:31 | notice | SW Download INIT - Via NMS |
17-10-2022 03:04:47 | error | SW upgrade Failed before download -TFTP Max Retry Exceeded |
17-10-2022 03:04:35 | notice | SW Download INIT - Via NMS |
17-10-2022 02:04:40 | error | SW upgrade Failed before download -TFTP Max Retry Exceeded |
17-10-2022 02:04:28 | notice | SW Download INIT - Via NMS |
17-10-2022 01:04:37 | error | SW upgrade Failed before download -TFTP Max Retry Exceeded |
17-10-2022 01:04:25 | notice | SW Download INIT - Via NMS |
As the Hub 5 is activated and provisioned accordingly, I'll just leave it, it may solve itself if it manages to pull the firmware update, or if it just happens to resolve itself.
on 18-10-2022 06:49
Looks like it managed to do the software update. As there's an entry indicating a reboot early this morning
18-10-2022 01:08:44 | critical | Cable Modem Reboot due to master console reset |
Software version is now: LG-RDK_3.18.30-2112.12
Telephony now shows as (Ready) on the status page in modem mode. So looks like it's sorted itself as mentioned!
on 20-10-2022 08:58
Good Morning :@jamesmacwhite, thanks for your post and welcome back to our Forums!
Can you please confirm if the green light is still flashing?
Are all services working on the hub as expected?
Kindest regards,
David_Bn
on 24-10-2022 07:22
Everything is OK. It would appear the software update happened after several days of the green light flashing and rebooted itself. From reading the replies and other posts, it seems I'm not the only one who has noticed it, but to be fair everything worked fine when activated despite this.
on 26-10-2022 08:59
Hi jamesmacwhite,
Thank you for reaching back out to us and for the update, glad to hear everything has worked fine since the activation, if you do need any further help/ support do not hesitate to reach back out, you can find out more around our landline switchover here.
Paul.
