on 14-12-2023 15:52
I'm wondering if anyone from customer service can help me here please.
Last week I had a call from Broadband Reliability Team who said they had noticed a high number of disconnects on my broadband, I personally hadn't noticed losses of connectivity however streaming radio and some other services on Sonos is struggling since I had my Hub 5 and Gig1 installed.
They sent an engineer who just added an attenutator to drop the signal down a bit but issues are still persisting and I'm even noticed hangs in my internet browsing and services on desktop computers reporting intermittent disconnections.
Find logs below.
3.0 Upstream channels
0 | 49600000 | 52 | 5120 | QAM 64 | 1 |
1 | 43100000 | 51.8 | 5120 | QAM 64 | 2 |
2 | 36600000 | 51.8 | 5120 | QAM 64 | 3 |
3 | 30100000 | 51.3 | 5120 | QAM 64 | 4 |
4 | 23600000 | 51.3 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 2 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
3.1 Upstream channels
6 | 10 | 45.7 | 2K | QAM 256 |
6 | OFDMA | 200 | 74000000 | 0 | 0 |
3.0 Downstream channels
1 | 331000000 | 7.5 | 44 | QAM 256 | 25 |
2 | 139000000 | 7.1 | 43 | QAM 256 | 1 |
3 | 147000000 | 7 | 43 | QAM 256 | 2 |
4 | 155000000 | 7 | 43 | QAM 256 | 3 |
5 | 163000000 | 6.9 | 43 | QAM 256 | 4 |
6 | 171000000 | 7 | 43 | QAM 256 | 5 |
7 | 179000000 | 7.2 | 43 | QAM 256 | 6 |
8 | 187000000 | 7.4 | 44 | QAM 256 | 7 |
9 | 195000000 | 7.5 | 43 | QAM 256 | 8 |
10 | 203000000 | 7.4 | 44 | QAM 256 | 9 |
11 | 211000000 | 7.6 | 44 | QAM 256 | 10 |
12 | 219000000 | 7.7 | 44 | QAM 256 | 11 |
13 | 227000000 | 7.7 | 44 | QAM 256 | 12 |
14 | 235000000 | 7.7 | 44 | QAM 256 | 13 |
15 | 243000000 | 7.6 | 44 | QAM 256 | 14 |
16 | 251000000 | 7.4 | 43 | QAM 256 | 15 |
17 | 259000000 | 7.5 | 44 | QAM 256 | 16 |
18 | 267000000 | 7.7 | 44 | QAM 256 | 17 |
19 | 275000000 | 7.7 | 44 | QAM 256 | 18 |
20 | 283000000 | 7.6 | 43 | QAM 256 | 19 |
21 | 291000000 | 7.7 | 43 | QAM 256 | 20 |
22 | 299000000 | 7.7 | 43 | QAM 256 | 21 |
23 | 307000000 | 7.8 | 44 | QAM 256 | 22 |
24 | 315000000 | 7.7 | 44 | QAM 256 | 23 |
25 | 323000000 | 7.6 | 44 | QAM 256 | 24 |
26 | 339000000 | 7.8 | 44 | QAM 256 | 26 |
27 | 347000000 | 8 | 44 | QAM 256 | 27 |
28 | 355000000 | 8 | 44 | QAM 256 | 28 |
29 | 363000000 | 8 | 44 | QAM 256 | 29 |
30 | 371000000 | 7.9 | 44 | QAM 256 | 30 |
31 | 379000000 | 8 | 44 | QAM 256 | 31 |
1 | Locked | 44 | 30 | 0 |
2 | Locked | 43 | 4 | 0 |
3 | Locked | 43 | 31 | 0 |
4 | Locked | 43 | 4 | 0 |
5 | Locked | 43 | 7 | 0 |
6 | Locked | 43 | 3 | 0 |
7 | Locked | 43 | 1 | 0 |
8 | Locked | 44 | 0 | 0 |
9 | Locked | 43 | 2 | 0 |
10 | Locked | 44 | 2 | 0 |
11 | Locked | 44 | 3 | 0 |
12 | Locked | 44 | 3 | 0 |
13 | Locked | 44 | 6 | 0 |
14 | Locked | 44 | 6 | 0 |
15 | Locked | 44 | 4 | 0 |
16 | Locked | 43 | 11 | 0 |
17 | Locked | 44 | 11 | 0 |
18 | Locked | 44 | 10 | 0 |
19 | Locked | 44 | 11 | 0 |
20 | Locked | 43 | 15 | 0 |
21 | Locked | 43 | 24 | 0 |
22 | Locked | 43 | 26 | 0 |
23 | Locked | 44 | 20 | 0 |
24 | Locked | 44 | 20 | 0 |
25 | Locked | 44 | 20 | 0 |
26 | Locked | 44 | 25 | 0 |
27 | Locked | 44 | 25 | 0 |
28 | Locked | 44 | 24 | 0 |
29 | Locked | 44 | 19 | 0 |
30 | Locked | 44 | 23 | 0 |
31 | Locked | 44 | 24 | 0 |
3.1 Downstream channels
159 | 94 | 4K | 1840 | QAM 4096 | 1108 |
159 | Locked | 44 | 7.7 | 808560225 | 0 |
on 14-12-2023 16:21
All upstream power levels are too high and the 3.1 downstream channel has high levels of (corrected) errors. The tech should have spotted this stuff really.
on 14-12-2023 18:34
This snapshot doesn't reveal the issue. Maybe after it has collected codeword stats for a longer time. The network/event log may have more details.
on 17-12-2023 08:48
Apologies for the connection issues. You do need a tech as pointed out (thank you to the community).
on 17-12-2023 12:49
So just done my own troublshooting here and quite quickly I'm becoming aware the problem is the Hub 5's router, although the power levels might be out a bit on the modem my issues are quite clearly the router in the Hub 5.
on 17-12-2023 16:23
Continuing to troubleshoot these issues this afternoon, and interesting case here is that if I try streaming radio in my browser with VPN enabled I don't have the dropouts!!
Come off the VPN and nearly immediately issues return.
17-12-2023 16:25 - edited 17-12-2023 16:29
You should probably remove your public IP from that image.
Apologies if it's not.
on 17-12-2023 16:42
It's not but thanks.
on 30-12-2023 13:47
Well I can confirm that engineer has been out this week and confirmed my tap and bank placement at the cab is correct, cables are all fine when checking against neighbouring connections, has added a forward path attenuator to manage the upstream power levels and confirmed everything is within scope but issues still remain.
