Hub 4 to Hub 5
AS
Good afternoon.
Virgin have advised they are sending me a Hub 5. Nice (I hope). Are there handy guides to connecting devices viz PC, laptop, LG TV, Ipads, Alex devices?
5 REPLIES 5
No guides that I know of. Wired devices just plug in and the WiFi name and password will be on the bottom of the Hub.
grumpywurzel
Dialled in
It's fairly standard tbh, the cables in the Hub 4 go into the same ports as the new one. You need the give the connect app a few days to update but it should be fairly easy. It does take an age for the hub to come out of hibernation tho, about 10-15 mins and will reboot a few times.
AS
1. Advice for other stuff (e.g. Alexa) suggests changing SSID and password back to the current ones. Can I do this straight away or do I need to let things settle down?
2. Do I need to wait for Virgin to 'turn off' the old hub, or do we just open the box and crack on?
Thanks for kind assistance
AS
Hi @AS
Welcome back to our community forums. We are glad to see you are getting a hub upgrade. You can find out all you need to know about quick-start installation and connecting your devices here https://www.virginmedia.com/broadband/installation When you receive your kit, you should be able to set it up right away.
Akua_A
AS
Thank you. The 'Idiot's Guide' included in the pack was pretty explicit and all went well. Since I possess a variety of devices including a number of Echos (Echoes?) advice to change the name and password back to its predecessor was also invaluable. Why do people refer the 'name' of the router as the SSID? Unexplained acronyms are a pest.
