Hoiman
Message 1 of 14
Hub 4 red light
New joined VM at new house, and self install the hub already  but cannot to connect internet and hub 4 have red light (Tried reset and reboot the device, but still not work) please advise how to fix it ? Thanks
Hoiman 
Tags (1)
lotharmat
  • 3.85K
  • 259
  • 724
Community elder
Message 2 of 14
Re: Hub 4 red light
Have you phoned in to get it activated ?
Hub Activation number - 0800 953 9500
Jakubkot
  • 6
Message 3 of 14
Re: Hub 4 red light
Hi. Is it normal for hub 4 to display red light if not activated over the phone?
First hub 4 I received displayed red light. I thought it faulty as hub was clearly used before by someone else (return sent to me by mistake). Replacement arrived yesaterday but I'm still getting red light.
Jakub
Steven_L
  • 8.9K
  • 537
  • 910
Message 4 of 14
Re: Hub 4 red light
Hey @Jakubkot,
Welcome to the community and thanks for taking the time to post here on our forums.
I'm sorry to hear that you're having issues with the Hub 4 and red light.
The red light on the hub 4 means that there could be an issue with the cable connections, please can you make sure that all of the connections are pushed in firmly, if you are still having this issue.
Please let me know if this helps at all.
Regards,
Steven_L
Jakubkot
  • 6
Message 5 of 14
Re: Hub 4 red light
Cable must be connected in correct way as Hub 3  been working without any issues for last few years. As I learnt more about Hub 4 since this problem arisen  I'm not sure whether I should upgrade at all due to potential overheating issues (With Hub 5 being about six months away) . It seems bad design of Hub 4 is preventing it from maintaining low temperature.
Nathan_B
  • 4.16K
  • 121
  • 276
Message 6 of 14
Re: Hub 4 red light
Thanks for your reply @Jakubkot
Just to confirm after checking the connections and rebooting does the hub still have this red light?
Is your hub also overheating at all? If so please do let me know.
Nathan
Jakubkot
  • 6
Message 7 of 14
Re: Hub 4 red light
Yes still red light and temperature seems ok. I phoned customer service only to be told that Hub 4 isn't compatible with Gig 1 broadband!!!! They ordered Hub 5 for me. Don't know what was a point of sending me Hub 4 in first place but at least I'm going be able to fully utilize internet with 2.5 Gbit port.
Ashleigh_C
  • 3.39K
  • 133
  • 265
Message 8 of 14
Re: Hub 4 red light
I'm so sorry to hear this @Jakubkot!
The Hub 4 should be compatible with Gig1 I'm so sorry that you were told otherwise.
Has your new Hub 5 arrived and been installed yet?
Thank you.
Ash_C
Jakubkot
  • 6
Message 9 of 14
Re: Hub 4 red light
No, at this point I don't think if it was sent to me ☹️☹️☹️
  • 11.61K
  • 898
  • 2.29K
Message 10 of 14
Re: Hub 4 red light
Red light on Hub4 is not overheating, that’s only applicable to a Hub3. It means you have no connection.
