Hub 4 not connected
DaveThorn
My hub 4 just won't connect to the connect app.  It just says my network isn't recognised.
I've reinstalled the app and reset the hub 4 with no change
3 REPLIES 3
davef28
I have same issue. The Hub 4 is working with my own SSID and phone connected but cannot connect via Connect App
I had a bit of luck when I rebooted the hub by holding down the button for 45 seconds... but I've been here before so I'll see how long it lasts
Kath_F
Hi DaveThorn,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
We're sorry to hear you're having an issue with the Connect App recognising your hub.
The first thing to be aware of is you need to be connected to your Home WiFi in order for the app to connect to the Hub. It won't allow the connection if you're on a Guest network, VPN or Mobile data. If this still doesn't help, try clearing the data within the Connect App. These steps will help you do that:
  • For your Apple device, you can try this: Open Settings > Tap your name > Tap iCloud > Tap Manage Settings > Tap the Connect App > Tap Delete Data.
  • For your Android device, you can try this: Open settings > Apps > Connect App > Storage > Clear data / Clear cache.
If this also fails then we currently have a known error with some of the data in our systems, that is causing the app to not recognise the Hub in a minority of instances. We are already investigating this as a high priority.
Pop back and keep us posted.
Kath_F
