Manuneedhi
  • 5
Message 1 of 10
Hub 4 no virgin box on the wall
I received a hub 4 today and when I tried to self install, I couldn't find a virgin box for the wall socket end of the cable to fix in. All I can see is a cable that won't fit to the wall socket cable.
Manuneedhi
  • 5
Message 2 of 10
Re: Hub 4 no virgin box on the wall
stabilo00
  • 239
  • 32
  • 52
Superfast
Message 3 of 10
We need a pic of other cable as well but usually one of these will connect them both if the other cable is off Virgin. Can you trace it to a usually brown box outside ?
https://www.diy.com/departments/tristar-data-cable-coupler/571706_BQ.prd
Manuneedhi
  • 5
Message 4 of 10
Thanks. Here is the other cable.
stabilo00
  • 239
  • 32
  • 52
Superfast
Message 5 of 10
If thats the one virgin have sent with the kit then that should push fit on to the connector that I have linked. I assume the first pic is of the existing cable. That should go to a box outside. If so that will screw onto the other side of the connector,
Zach_R
  • 458
  • 18
  • 33
Message 6 of 10
Hi @Manuneedhi,
Thank you for your post, and welcome to our community forums. We're here to help.
I do apologise for the delayed response here. Have you since been able to resolve this matter, or do you require some further assistance?
Zach - Forum Team
Manuneedhi
  • 5
Message 7 of 10
I had a spare  attenuator with me , I used it to resolve the issue. Thanks
Zach_R
  • 458
  • 18
  • 33
Message 8 of 10
Hi @Manuneedhi,
Thanks for the update on this. I'm really glad to hear that you've been able to resolve this.
If there's anything else we can help you out with in the future, please don't hesitate to reach out.
Zach - Forum Team
Manuneedhi
  • 5
Message 9 of 10
@Zach_R
Does an attenuator reduce the broadband speeds to the computer?
I am trying to understand the difference between an attenuator and a data coupler.
Manu
  • 2.89K
  • 217
  • 616
Trouble shooter
Message 10 of 10
@Manuneedhi wrote:
@Zach_R
<snip>
 No, attenuators reduce the power levels to the Hub by the amount marked on it, e.g. 4dba would reduce by 4
It does not affect the speed, but if your power levels were incorrect to begin with, an FPA would make matters worse.  So, check your power levels now 🙂 Downstream should be -6 to +10 and Upstream 34 to 51.
Data couplers only join the cables and have no affect on the speed.
