on 09-09-2022 10:09
I have just received my Hub 4 for 1 gig and swapped over from my Hub 3. It has gone through all the different light procedures including the flashing green to say updating software and is now a dim solid white light.
When I try to login to the settings on 192.168.0.1 it just says it is updating software and to wait and then kicks it back to language selection, it has been well over 1 hour now. Manual that came with it said it should take 10 mins?
The WiFi network is showing and I can connect but it says no Internet.
Have I got a dead Hub or do I just need to keep waiting? Seems odd to have a white light but says its updating?
Answered! Go to Answer
on 11-09-2022 17:02
Hi Widget,
Thanks for your post and welcome to the forums. It's great having you on board with us in the Community.
I'm sorry to hear you were having an issue with your Hub on Friday.
Taking a look at things this end, I can see the Hub is showing as online now so I'm hoping this means you're no longer having an issue.
If you are still having issues, pop back and let us know so we can help you further.
on 09-09-2022 15:16
on 11-09-2022 17:02
Hi Widget,
on 12-09-2022 10:56
Yes, it is all working ok now, I just left it as I had to go to work and when I returned in the evening it was working OK, must have just taken awhile to sort the updates.
