shinta
Hub 4 no connection
I've just received my new "Super" hub 4 in the mail today. Set up as it says in the installation guide. Everything boots up fine but I cannot get an internet connection.
I have received countless text messages saying my connection is active and I have switched back to my old Hub 3 and I'm getting a steady connection from it but when it comes to the hub 4... Nothing... Nada... Zip... Sweet Nothings.
Supposedly it's meant to be "quick" but for over 5-6 hours of racking my brain I'm just tempted to phone back up tomorrow ask them to revert my package and maybe try elsewhere so my last ditch attempt as the call centers have packed up for the night is here with the community can you please help this stressed out guy?
Tags (2)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Re: Hub 4 no connection
You can only have one active Hub on the line, with the Hub 3 working it tells me that the Hub 4 wasn't activated.
All new installs / replacement electronic equipment need to be activated.
You can try the Activation number -  0800 953 9500
Best time to phone is 08:00
Or
You can wait on here for one of the VM Staff to pick up the thread but this may take a few days.
shinta
Clearly you haven't read my message properly.
I have phoned the activations line which now diverts to the normal options menu as if I called customer services. I have received confirmation text messages stating that it is ACTIVE.
I have also went through all the basic troubleshooting procedures as with any piece of electronical equipment (i.e. Turning it on and off again, letting it power cycle, resetting it back to factory settings, etc.)
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
OK your new Hub 4 is active.
Your choice, accept what I am saying or sit forever more looking at your shiny new Hub 4 sat in a corner doing nothing.
-tony-
  • 16.93K
  • 1.32K
  • 4K
the system has to be wrong - Mike is correct - if you can access the internet on the hub3 then the activation has not worked on the hub4 - i guess there could be a delay - if the hub3 stops working then that would suggest the activation on the hub4 has worked
BUT regardless of what the system is telling you the hub4 is not correctly activated
____________________
Tony
d_lisy
Clearly YOU haven't read what he said. Read the advice properly before coming back with such an awful attitude. As with all networks you can only have ONE router active with your service at any given time. If your HUB 3 works then your HUB 4 isn't activated, regardless of your 'countless' texts. Apologise, take the advice and go phone Virgin to get the new HUB properly provisioned. You'll know it's done when your HUB 3 stops working. Simple.
