MHVMSA
  • 8
Message 1 of 7
Hub 4 lag spikes and dropout
Hi there,
Recently upgraded to the Hub 4 and now I’m seeing connection drop outs. In addition, whilst gaming I am experiencing lag spikes every 15 - 20 seconds (over Ethernet)
I had a quick look at the logs and could see t3 timeout.
Couldn’t see any advice on the best way to share logs so feel free to point me in the right direction.
Thanks!
-tony-
  • 16.91K
  • 1.32K
  • 4K
Message 2 of 7
Re: Hub 4 lag spikes and dropout
just cut and paste the pages - also post upstream and downstream levels
____________________
Tony
MHVMSA
  • 8
Message 3 of 7
Thanks Tony, here they are (I've deleted the Mac Addresses)
3.0 Downstream channels
2 146750000 3.799999 38.605377 QAM256 2
1 138750000 3.799999 38.605377 QAM256 1
3 154750000 3.400002 38.983261 QAM256 3
4 162750000 3.200001 38.605377 QAM256 4
5 170750000 3.099998 38.605377 QAM256 5
6 178750000 2.900002 38.983261 QAM256 6
7 186750000 3.000000 38.605377 QAM256 7
8 194750000 3.000000 38.605377 QAM256 8
9 202750000 3.099998 38.983261 QAM256 9
10 210750000 3.099998 38.983261 QAM256 10
11 218750000 3.200001 38.983261 QAM256 11
12 226750000 3.000000 38.983261 QAM256 12
13 234750000 3.099998 38.605377 QAM256 13
14 242750000 3.099998 38.605377 QAM256 14
15 250750000 3.200001 38.983261 QAM256 15
16 258750000 3.599998 38.983261 QAM256 16
17 266750000 3.700001 38.983261 QAM256 17
18 274750000 3.400002 38.983261 QAM256 18
19 282750000 2.599998 38.983261 QAM256 19
20 290750000 2.500000 38.983261 QAM256 20
21 298750000 2.299999 38.983261 QAM256 21
22 306750000 3.000000 40.366287 QAM256 22
23 314750000 3.099998 40.366287 QAM256 23
24 322750000 3.400002 38.983261 QAM256 24
25 330750000 3.299999 38.983261 QAM256 25
26 370750000 3.000000 40.366287 QAM256 26
27 378750000 3.000000 40.366287 QAM256 27
28 386750000 3.099998 40.366287 QAM256 28
29 394750000 2.900002 40.366287 QAM256 29
30 402750000 2.799999 38.983261 QAM256 30
31 410750000 2.900002 40.946209 QAM256 31
2 Locked 0 0 0
1 Locked 117319253 0 0
3 Locked 108676439 0 0
4 Locked 123381603 0 0
5 Locked 118251011 0 0
6 Locked 1452853834 0 0
7 Locked 123069290 0 0
8 Locked 60474435 0 0
9 Locked 60719487 0 0
10 Locked 67217817 0 0
11 Locked 64954576 0 0
12 Locked 65475709 0 0
13 Locked 59985558 0 0
14 Locked 61113637 0 0
15 Locked 63414908 0 0
16 Locked 57026946 0 0
17 Locked 57721345 0 0
18 Locked 55708060 0 0
19 Locked 1404550388 0 0
20 Locked 51106427 0 0
21 Locked 59603386 0 0
22 Locked 59588397 0 0
23 Locked 59808364 0 0
24 Locked 97881824 0 0
25 Locked 1398781958 0 0
26 Locked 107414488 0 0
27 Locked 101727955 0 0
28 Locked 104855030 0 0
29 Locked 99745881 0 0
30 Locked 102333125 0 0
31 Locked 1427260784 0 0
3.1 Downstream channels
33 86 4K 1680 QAM4096 424
33 Locked
3.2 677290541 0
3.0 Upstream channels
1 32600000 42.020599 5120 KSym/sec 64QAM 5
2 46200000 42.270599 5120 KSym/sec 64QAM 3
3 53700000 42.520599 5120 KSym/sec 64QAM 2
4 39400000 42.270599 5120 KSym/sec 64QAM 4
1 US_TYPE_STDMA 0 0 1 0
2 US_TYPE_STDMA 0 0 1 0
3 US_TYPE_STDMA 0 0 1 0
4 US_TYPE_STDMA 0 0 1 0
Thu 01/01/1970 02:10:40 3 No Ranging Response received - T3 time-out;CM-MAC=********;CMTS-MAC=*******;CM-QOS=1.1;CM-VER=3.1;
Thu 29/10/2020 09:34:30 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=*********;CMTS-MAC=********;CM-QOS=1.1;CM-VER=3.1;
Thu 01/01/1970 00:01:16 3 No Ranging Response received - T3 time-out;CM-MAC=********;CMTS-MAC=********CM-QOS=1.1;CM-VER=3.1;
Fri 30/10/2020 17:49:12 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=********;CMTS-MAC=********;CM-QOS=1.1;CM-VER=3.1;
MikeRobbo
  • 15.27K
  • 1.17K
  • 1.94K
Message 4 of 7
MHVMSA
  • 8
Message 5 of 7
Thanks for the response, fingers crossed this is correct!
My BQM graph
MHVMSA
  • 8
Message 6 of 7
Realised it wasn't setup correctly so have started a new monitor here: Updated graph
I've also tried a new router as well which seems to have made a slight improvement. Still a little jittery though.
Thanks for any input.
MHVMSA
  • 8
Message 7 of 7
Noticing some packet loss during the night on this graph, does that shed any light on what's going on for anyone?
Any input on if this is a normal looking graph? It's got some large spikes throughout the day...
