tim_hamblin
  • 6
Message 1 of 8
Hub 4 drop in Upstream speed
Over the last week or so I've noticed a drop in the Upstream speed of my 1 Gig broadband.
There has been no change in the internal network at home, connection via known good Ethernet cabling.
I normally use my Hub 4 in modem mode, so have limited web UI access (appears to be a known issue with web access to the Hub 4 needing a reboot to restore access after about a day).
I did a reset and put the Hub 4 back to router mode, and then a RealSpeed test on SamKnows:
2020-09-22 21_44_49-RealSpeed - SamKnows and 1 more page - Personal - Microsoft​ Edge.jpg
So the Download speed looks correct, however the Upload speed is poor, with increased latency and a bit of packet loss.
Previous SpeedTest.net results have been very good with typical 945/55 and 9ms latency results; however these are now showing a drop in Upload and increase in latency:
Network Stats from the Hub 4 to follow (as need to restart it to get the web UI working again).
tim_hamblin
  • 6
Message 2 of 8
Re: Hub 4 drop in Upstream speed
Hub 4 Network Status (please note recently factory reset 22/09/20, and restarted 24/09/20):
Cable Modem Status
ItemStatusComments
Cable Modem Status
Online
DOCSIS 3.1
Primary downstream channel
Locked
SC-QAM
Channel OverviewDownstreamUpstream
DOCSIS 3.0 channels
31
4
DOCSIS 3.1 channels
1
0
3.0 Downstream channels
1411000000-1.20000136.609653QAM2561
2419000000-1.20000136.38689QAM2562
3427000000-1.40000236.38689QAM2563
4435000000-0.90000237.355988QAM2564
5443000000-0.90000236.609653QAM2565
6451000000-0.537.636276QAM2566
7459000000-0.537.355988QAM2567
8467000000-0.29999937.355988QAM2568
9475000000-0.09999837.355988QAM2569
10483000000-0.09999837.636276QAM25610
11491000000037.355988QAM25611
12499000000037.355988QAM25612
13507000000037.636276QAM25613
145150000000.20000137.355988QAM25614
155230000000.20000137.636276QAM25615
165310000000.29999937.636276QAM25616
175390000000.40000237.355988QAM25617
185470000000.537.355988QAM25618
195550000000.59999837.355988QAM25619
205630000000.59999837.355988QAM25620
215710000000.59999837.636276QAM25621
225790000000.537.355988QAM25622
235870000000.59999837.636276QAM25623
245950000000.59999837.636276QAM25624
256030000000.59999837.355988QAM25625
266110000000.59999837.636276QAM25626
276190000000.537.636276QAM25627
286270000000.40000236.609653QAM25628
296350000000.09999837.355988QAM25629
306430000000.20000137.355988QAM25630
316510000000.20000137.636276QAM25631
ChannelLock StatusRxMER (dB)Pre RS ErrorsPost RS Errors
1Locked010
2Locked25255310
3Locked25060620
4Locked23934000
5Locked23670800
6Locked25159300
7Locked25251910
8Locked20994800
9Locked21324800
10Locked20663400
11Locked21466200
12Locked21927500
13Locked21466600
14Locked19483000
15Locked21006510
16Locked19786200
17Locked22695000
18Locked21015900
19Locked21466600
20Locked22081000
21Locked21171400
22Locked20545600
23Locked20853000
24Locked28611700
25Locked28833810
26Locked28041500
27Locked28372900
28Locked29126410
29Locked28671010
30Locked28707400
31Locked16889108110
3.1 Downstream channels
ChannelChannel Width (MHz)FFT TypeNumber of Active SubcarriersModulation (Active Profile)First Active Subcarrier (Hz)
159964K1880QAM4096728
Channel IDLock StatusRxMER Data (dB)PLC Power (dBmV)Correcteds (Active Profile)Uncorrectables (Active Profile)
159Locked 1.344386410
3.0 Upstream channels
ChannelFrequency (Hz)Power (dBmV)Symbol Rate (ksps)ModulationChannel ID
15370000037.0205995120 KSym/sec64QAM10
23940000037.2705995120 KSym/sec64QAM12
34620000037.2705995120 KSym/sec64QAM11
46030000037.7705995120 KSym/sec64QAM9
General Configuration
Network access
TRUE
Maximum Number of CPEs
1
Baseline Privacy
TRUE
DOCSIS Mode
3.1
Config file
wrkldJKDHSUBsgvca69834ncxv987
SFID
860
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
859
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
TimePriorityDescription
Thu 01/01/1970 00:01:204Missing Mandatory MDD TLV on primary DS Channel;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 22/09/2020 21:39:565MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 22/09/2020 21:50:373No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/09/2020 11:00:375MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
tim_hamblin
  • 6
Message 3 of 8
The information below shows current status of this Hub 4.
Standard specification compliant: DOCSIS 3.1
Hardware version: 8
Software version: 01.02.048.09.EURO.PC20(Open Source Information)
Cable MAC address: E4:57:40:xx:xx:xx
Cable modem serial number: A8AP93625204
System up time: 0 days 0h:38m:12s
Network access: Allowed
Kev_B
  • 8.07K
  • 288
  • 920
Community Manager (Retired)
Message 4 of 8
Hi tim_hamblin,
Welcome to the community 🙂 I'm sorry to see the upload speeds have dropped on your connection lately.
I can see some issues on the upstream channels around the time you posted. It does look like there were a fair few errors on upstream data. Things have settled down since the weekend. I've tested the hub and network again today and everything looks fine at the moment. Will you keep an eye on things please, and let me know if the problems persist?
Kev
tim_hamblin
  • 6
Message 5 of 8
Hi Kev_B,
Thanks for checking things...
SpeedTest upload seems to be a lot better now (Hub 4 in modem mode)...
Looking on the Hub 4 web UI, can see there have been Upstream T3 timeouts and Uncorrectable errors on the 3.1 downstream (since the reboot of 24/09/20):
ChannelChannel TypeT1 TimeoutsT2 TimeoutsT3 TimeoutsT4 Timeouts
1US_TYPE_STDMA00290
2US_TYPE_STDMA00290
3US_TYPE_STDMA00290
4US_TYPE_STDMA00290
159Locked 1.7282040557458
And the Network logs look interesting since last checked (after 24/09/20 @ 11:07) for yesterday and the day before:
Thu 24/09/2020 13:21:223No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/09/2020 14:05:153SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/09/2020 14:05:195Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/09/2020 14:05:526CM-STATUS message sent. Event Type Code: 4; Chan ID: 2; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/09/2020 14:08:273SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/09/2020 14:08:315Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/09/2020 14:08:586CM-STATUS message sent. Event Type Code: 5; Chan ID: 18; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/09/2020 14:23:525DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 24/09/2020 14:41:533No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 06:30:204DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 10:18:483No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 22:15:204DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 29/09/2020 22:41:573No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 30/09/2020 06:07:494DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 30/09/2020 06:22:323No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 30/09/2020 10:04:044DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 30/09/2020 10:38:083No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 30/09/2020 12:02:114DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 30/09/2020 14:00:224DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 30/09/2020 14:00:226DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 30/09/2020 17:07:503No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
I'll reboot the Hub, and keep an eye on things...
Megan_L
  • 2.68K
  • 162
  • 281
Message 6 of 8
Hi tim_hamblin,
Thanks for the update on how your HUB is performing, now that its been a few days I just want to check in on how things are now?
If you are still encountering issues then please try rebooting your HUB and do another speed test and BMQ test so I can see what is happening please 🙂
Megan_L
tim_hamblin
  • 6
Message 7 of 8
Hi Megan,
Thanks for the follow-up...
Speeds appear to be normal/still stable...
https://www.speedtest.net/my-result/d/e7d660bf-8c58-49e5-ad57-85cc55731787
I had to reboot the Hub 4 this morning - as the webUI wasn't accessible to check the Network status...
Here's the Network Log since the last reboot on the 01/10/20:
Thu 01/10/2020 21:04:135MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 01/10/2020 23:53:183No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Tue 06/10/2020 16:33:564DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 11:58:583No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Wed 07/10/2020 16:11:274DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 08/10/2020 00:03:594DHCP REBIND WARNING - Field invalid in response;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 08/10/2020 00:03:596DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Thu 08/10/2020 11:59:003No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 10/10/2020 08:32:325
Currently there are no T3 timeouts showing on the Upstream (however only been up for a few hours).
Prior to the Hub4 webUI being inaccessible, I do recall that since the reboot on 01/10 after three days there were 29 T3 timeouts on the Upstream.
Are VM working on a new firmware to address the loss of Hub 4 webUI access (which requires a reboot to resolve)?
tim_hamblin
  • 6
Message 8 of 8
Got BQM working now (Hub 4 in modem mode with Asus RT-AX88U) - here's the graph for the last 24 hours:
