Hub 4 - Fan constantly running?
Jon22
Dialled in
Just rejoined Virgin Media on the 500Mb broadband only. A Hub 4 was provided. Is it normal for the fan to be running all the time? I thought it would only come on when needed. I have the Hub 4 in modem mode, the light ring is off (seen that it somehow makes a difference?). It’s not particularly loud but it came on pretty much as soon as I switched the Hub on.
Could I also get a check on the power levels. I've had to attach a 10dB Forward Path Attenuator to the cable as the downstream levels were between 15-20dBmV. Everything appears to be working fine though.
3.0 Downstream channels
253310000005.09999840.366287QAM25625
11390000009.09999840.946209QAM2561
21470000009.30000340.366287QAM2562
31550000009.30000340.366287QAM2563
41630000008.00000040.366287QAM2564
51710000007.09999840.366287QAM2565
61790000006.40000240.946209QAM2566
71870000006.40000240.366287QAM2567
81950000005.90000240.946209QAM2568
92030000005.59999840.366287QAM2569
102110000005.59999840.366287QAM25610
112190000005.50000040.366287QAM25611
122270000005.30000340.366287QAM25612
132350000005.40000240.366287QAM25613
142430000005.69999740.366287QAM25614
152510000005.69999740.366287QAM25615
162590000006.40000240.946209QAM25616
172670000006.80000340.366287QAM25617
182750000007.30000340.366287QAM25618
192830000007.00000040.366287QAM25619
202910000006.90000240.366287QAM25620
212990000006.50000040.366287QAM25621
223070000007.00000040.366287QAM25622
233150000006.40000240.366287QAM25623
243230000005.40000240.366287QAM25624
263390000005.50000040.366287QAM25626
273470000005.40000240.946209QAM25627
283550000005.59999840.366287QAM25628
293630000005.69999740.946209QAM25629
303710000005.90000240.366287QAM25630
313790000005.80000340.366287QAM25631
25Locked40.36628700
1Locked40.94620900
2Locked40.36628700
3Locked40.36628700
4Locked40.36628700
5Locked40.36628700
6Locked40.94620900
7Locked40.36628700
8Locked40.94620900
9Locked40.36628700
10Locked40.36628700
11Locked40.36628700
12Locked40.36628700
13Locked40.36628700
14Locked40.36628700
15Locked40.36628700
16Locked40.94620900
17Locked40.36628700
18Locked40.36628700
19Locked40.36628700
20Locked40.36628700
21Locked40.36628700
22Locked40.36628700
23Locked40.36628700
24Locked40.36628700
26Locked40.36628700
27Locked40.94620900
28Locked40.36628700
29Locked40.94620900
30Locked40.36628700
31Locked40.36628700
3.1 Downstream channels
159964K1880QAM2048759
159Locked423.01806022020
21 REPLIES 21
Jon22
Dialled in
3.0 Upstream channels
15370000037.7705995120 KSym/sec64QAM2
23940000036.7705995120 KSym/sec64QAM4
34620000037.2705995120 KSym/sec64QAM3
46030000037.7705995120 KSym/sec64QAM1
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
The LED ring on a Hub4 with the latest firmware should be green in modem mode. The stats are ok, but you certainly need that 10dBm attenuator. From the upstream stats I think you should be on a different tap on the street box. As to the fan, mine runs always, but it is under the stairs with lots of other networking equipment.
Thank you. Out of interest, what is the latest firmware for the Hub 4? Mine shows: 01.02.065.21.EURO.PC20 and the LED ring is white in modem mode.
Mine is:
AR01.04.055.06.07_040722_7245.PC20.10.LG.X1
Jon22
Dialled in
Had some planned maintenance today. Now have an extra 3.0 and 3.1 upstream channel. Are the power levels ok? More especially the 3.1 channel, seems a little low, although everything appears to be ok. Haven't really noticed the fan in the Hub since posting, so can ignore that.
14310000037.0205995120 KSym/sec64QAM2
22360000036.5205995120 KSym/sec64QAM5
33010000036.5205995120 KSym/sec64QAM4
43660000037.0205995120 KSym/sec64QAM3
54960000038.2705995120 KSym/sec64QAM1
1US_TYPE_STDMA0060
2US_TYPE_STDMA0010
3US_TYPE_STDMA0010
4US_TYPE_STDMA0000
5US_TYPE_STDMA0010
3.1 Upstream channels
610.032.22KQAM8
6OFDMA20053.900
Jon22
Dialled in
Downstream as well for a full picture.
253310000004.50000038.983261QAM25625
11390000008.69999740.366287QAM2561
21470000008.69999740.366287QAM2562
31550000008.80000340.946209QAM2563
41630000007.50000040.366287QAM2564
51710000006.40000240.366287QAM2565
61790000005.59999840.366287QAM2566
71870000005.80000340.366287QAM2567
81950000005.19999738.983261QAM2568
92030000005.00000038.983261QAM2569
102110000004.69999740.366287QAM25610
112190000004.80000340.366287QAM25611
122270000004.59999838.983261QAM25612
132350000004.59999838.983261QAM25613
142430000004.90000240.366287QAM25614
152510000005.00000040.366287QAM25615
162590000005.69999740.366287QAM25616
172670000006.09999840.366287QAM25617
182750000006.59999840.366287QAM25618
192830000006.40000240.366287QAM25619
202910000006.19999740.366287QAM25620
212990000005.90000240.366287QAM25621
223070000006.19999740.366287QAM25622
233150000005.69999740.366287QAM25623
243230000004.69999740.366287QAM25624
263390000004.80000340.366287QAM25626
273470000004.80000340.946209QAM25627
283550000005.00000040.946209QAM25628
293630000004.90000240.366287QAM25629
303710000005.09999840.366287QAM25630
313790000005.19999740.366287QAM25631
25Locked38.98326100
1Locked40.36628700
2Locked40.36628700
3Locked40.94620900
4Locked40.36628700
5Locked40.36628700
6Locked40.36628700
7Locked40.36628700
8Locked38.98326100
9Locked38.98326100
10Locked40.36628700
11Locked40.36628700
12Locked38.98326100
13Locked38.98326100
14Locked40.36628700
15Locked40.36628700
16Locked40.36628700
17Locked40.36628700
18Locked40.36628700
19Locked40.36628700
20Locked40.36628700
21Locked40.36628700
22Locked40.36628700
23Locked40.36628700
24Locked40.36628700
26Locked40.36628700
27Locked40.94620900
28Locked40.94620900
29Locked40.36628700
30Locked40.36628700
31Locked40.36628700
159964K1880QAM4096759
159Locked422.7508798120
Jon22
Dialled in
Upstream power levels appear to be fluctuating, more especially the 3.1 upstream channel. Was showing 36.5dBmV earlier. Now down to 31.2dBmV. Not sure if that's an issue or not? Seen that around 35 is the recommended minimum? Appreciate that bumping seems to put threads to the back of the queue but this one seems to of been missed.
14310000036.5205995120 KSym/sec64QAM2
22360000035.7705995120 KSym/sec64QAM5
33010000035.7705995120 KSym/sec64QAM4
43660000036.0205995120 KSym/sec64QAM3
54960000037.0205995120 KSym/sec64QAM1
1US_TYPE_STDMA0060
2US_TYPE_STDMA0010
3US_TYPE_STDMA0010
4US_TYPE_STDMA0000
5US_TYPE_STDMA0010
610.031.22KQAM8
6OFDMA20053.900
Hi Jon22,
Thanks for your post and this is certainly something we can check for you but I've been unable to locate you on our systems using your forum credentials. I will need to confirm some information with you in order for me to proceed with checks.
I have sent you a private message regarding this and will investigate further once I receive your reply. Just click on the little plum envelope at the top right-hand side of the page to access your inbox.
Kath_F
Replied to the private message 🙂
