Hi Folks,
Been getting really slow speeds from my 1gb connection going through a google mesh setup. Tried all the various resets etc. Decided to try and isolate the problem. Found out the mesh to Hub connection is only synching at 100mb. Dug a bit deeper, and even plugging the laptops directly into hub via ethernet, its only getting 300mb. It all use to be great but has been terrible lately, and any issue, a reset would work. Tried different ports, different cables (cat 5/6 etc which i know are fine).
Real Speed shows 1100 coming to the hub, and its on Docsis 3.1.
Any clues, as its driving me up the wall, and trying to get hold of support is just a waste of time.
