daysofspeed
  • 99
Hub 4 / 1 GB - wifi slower than M200 it replaced
Set up and hit 900Mbps wired and 600Mbps wifi sat next to hub.
Slowed and now hitting 300Mbps wired and 50Mps across wifi (previously hit 195Mbps on Wifi with Hub 3 and M200).
Anything I can check?
DaftClanger
  • 15
Re: Hub 4 / 1 GB - wifi slower than M200 it replaced
I just got a hub 4, supposedly I should get over 550Mbps but getting same speed as I used to with my hub 3. Just been in the phone queue for an hour, 8pm hit, someone answered and then cut me off.
daysofspeed
  • 99
Have extended using TP Link Powerline extenders - Cat 5 from Hub 4 to link, out other end Cat 5 to AirPort Extreme - working well but (hard wired into AE) speeds are arcane - Down 40.5Mbps - Up - 51.3Mbps. Over Wifi sat next to AE on MacBook Pro - Down 30.3Mbps - Up - 48.2Mbps.
  • 26.33K
  • 2.69K
  • 4.88K
Cat5 cables will usually never get over 100Mbps - probably a lot less.
Bin them and get new Cat5e ones or even better Cat6/7 ones.
