Hub 3 with BT whole home wifi
To extend the Virgin Hub 3 broadband I got a BT whole home 3 disc wifi mesh system.
I assembled it per the app instructions and set up one disc in the router and 2 around the house.
Very disappointed to only be getting 10-20 mbps when connected to BT Home wifi and still 100+ near to the Virgin router.
I tried disabling the wifi from the virgin router but this made no difference at all.
Any suggestions before I send it back?
  • 953
  • 69
  • 133
Well-informed
Re: Hub 3 with BT whole home wifi
The bt system is more of a repeater than a proper mesh so you might have to make sure the discs are close enough together to get a good signal and make sure you are connected to the disc that is closest to you. If a dish is getting a poor signal you are going to get the same poor signal just amplified.
Does it make a difference if the WiFi is disabled on the Virgin router?
  • 7.56K
  • 596
  • 1.28K
Legend
Probably will make a difference. You have 4 devices on the 2.4 GHz band and there are only 3 clear channels to use, 1, 6 & 11. So the VM hub will be on one of the channels of one of the discs, so you would probably get interference. Mesh systems like this have an inherent problem in that unless all the ‘discs’ are cabled attached to the VM hub you will play pass-the-parcel with data. Some systems have a 3rd ‘backhaul’ channel (on the 5Ghz band) for talking between stations, but these still suffer from the problem of WiFi being half-duplex.
