Hub 3 problem
Barry007
My hub has now stop working, done the usual tricks but not working, getting 2 constant green flashing, i have booked a engineer coming next week, do they supply a new hub? All the cables are fine.
4 REPLIES 4
nodrogd
Your equipment is rented, so if anything is found to be faulty, it is replaced free of charge. The tech will check for wiring/signal issues first, & if no issues are found the hub will be replaced.
VM 350BB 2xV6 & Landline. Freeview/Freesat HD, ASDA/Tesco PAYG Mobile. Cable customer since 1993
Legend
Check all the coax cables are secure at the Hub and the wall sockets.
For an RFoG / FTTP area check the connections and PSU for the ONT.
Call 0800 561 0061 to see if this is a fault in your street.
  • My V6 box is now playing, if I leave for a few hours it just reboots itself, is this connected due to having no internet?
Roger_Gooner
If your V6 has no connection to the hub for more than a few weeks it will automatically become deactivated.
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
