24-10-2022 21:18 - edited 24-10-2022 21:30
My ageing Hub 3, running flawlessly in modem mode since day one, now appears to have developed a fault. Every few days, my Internet connection goes down completely. The Hub 3 stops responding to local pings. If I reboot it, it responds to pings again and everything is back to normal ... until next time.
Just before reboot:
ping 192.168.100.1
Pinging 192.168.100.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Immediately after reboot:
ping 192.168.100.1
Reply from 192.168.100.1: bytes=32 time=9ms TTL=63
Reply from 192.168.100.1: bytes=32 time=2ms TTL=63
Needless to say, very inconvenient. Could I order a replacement please?
Answered! Go to Answer
on 29-10-2022 11:12
Hi cylinder
Thanks for posting and welcome to the community. My apologies for the broadband issue. This is an area issue, you've got an SNR fault (signal to noise ratio). F010145545 - fault reference. Start date was the 29th September. Estimated fix date is the 31st October at 3pm. Please monitor the connection after this time and keep us posted if still happening.
Best wishes,
on 24-10-2022 21:31
Could be a hub problem, but most of these type of problems turn out to be a circuit problem. Please provide some stats.
How to get stats from a VM hub (no need to logon to the hub)
Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
on 24-10-2022 22:01
Thanks for the super speedy reply. Happy to. I thought the fact the Hub totally stopped responding to pings, network traffic, port 80 etc. would be fairly conclusive, but anything is possible! I don't have a "Networking" tab but went with "Network Log".
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
1 | 387000000 | 2.2 | 40 | 256 qam | 32 |
2 | 203000000 | 2.2 | 38 | 256 qam | 9 |
3 | 211000000 | 1.7 | 38 | 256 qam | 10 |
4 | 219000000 | 1.2 | 40 | 256 qam | 11 |
5 | 227000000 | 1.2 | 40 | 256 qam | 12 |
6 | 235000000 | 1.2 | 40 | 256 qam | 13 |
7 | 243000000 | 1.5 | 40 | 256 qam | 14 |
8 | 251000000 | 1.7 | 40 | 256 qam | 15 |
9 | 259000000 | 1.9 | 40 | 256 qam | 16 |
10 | 267000000 | 1.4 | 40 | 256 qam | 17 |
11 | 275000000 | 0.9 | 38 | 256 qam | 18 |
12 | 283000000 | 0.7 | 38 | 256 qam | 19 |
13 | 291000000 | 1.5 | 40 | 256 qam | 20 |
14 | 299000000 | 2.4 | 40 | 256 qam | 21 |
15 | 307000000 | 2.4 | 40 | 256 qam | 22 |
16 | 315000000 | 2 | 40 | 256 qam | 23 |
17 | 323000000 | 1.9 | 40 | 256 qam | 24 |
18 | 331000000 | 2 | 40 | 256 qam | 25 |
19 | 339000000 | 2.5 | 38 | 256 qam | 26 |
20 | 347000000 | 3 | 40 | 256 qam | 27 |
21 | 355000000 | 2.9 | 40 | 256 qam | 28 |
22 | 363000000 | 2.4 | 40 | 256 qam | 29 |
23 | 371000000 | 1.9 | 38 | 256 qam | 30 |
24 | 379000000 | 1.9 | 38 | 256 qam | 31 |
Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
1 | Locked | 40.3 | 1 | 0 |
2 | Locked | 38.9 | 6 | 0 |
3 | Locked | 38.9 | 6 | 0 |
4 | Locked | 40.3 | 6 | 0 |
5 | Locked | 40.3 | 5 | 0 |
6 | Locked | 40.9 | 4 | 0 |
7 | Locked | 40.3 | 4 | 0 |
8 | Locked | 40.3 | 5 | 0 |
9 | Locked | 40.3 | 4 | 0 |
10 | Locked | 40.3 | 6 | 0 |
11 | Locked | 38.9 | 5 | 0 |
12 | Locked | 38.9 | 0 | 0 |
13 | Locked | 40.3 | 5 | 0 |
14 | Locked | 40.3 | 6 | 0 |
15 | Locked | 40.9 | 5 | 0 |
16 | Locked | 40.3 | 6 | 0 |
17 | Locked | 40.3 | 5 | 0 |
18 | Locked | 40.3 | 4 | 0 |
19 | Locked | 38.9 | 6 | 0 |
20 | Locked | 40.3 | 5 | 0 |
21 | Locked | 40.9 | 5 | 0 |
22 | Locked | 40.3 | 6 | 0 |
23 | Locked | 38.9 | 4 | 0 |
24 | Locked | 38.9 | 4 | 0 |
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 30100000 | 46 | 5120 | 64 qam | 12 |
2 | 23600000 | 44.5 | 5120 | 32 qam | 13 |
3 | 36600000 | 46 | 5120 | 64 qam | 11 |
4 | 43100000 | 46 | 5120 | 64 qam | 10 |
5 | 49599986 | 46 | 5120 | 64 qam | 9 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
on 24-10-2022 22:03
24/10/2022 00:06:44 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/10/2022 10:52:10 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/10/2022 10:52:10 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/10/2022 16:04:22 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/10/2022 22:52:10 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/10/2022 22:52:10 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/10/2022 06:36:34 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/10/2022 00:55:7 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/10/2022 00:55:7 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
13/10/2022 12:30:24 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/10/2022 07:49:18 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/10/2022 07:49:18 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/10/2022 12:01:17 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/10/2022 19:49:19 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/10/2022 19:49:19 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/10/2022 00:35:15 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/10/2022 07:49:19 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/10/2022 07:49:19 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/10/2022 09:11:36 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/10/2022 19:49:19 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt060+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 24-10-2022 22:12
Oh, and in case useful - BQM today:
BQM yesterday:
Thanks!
on 24-10-2022 22:14
Just noticed the upstream stats have changed on a refresh:
2 | 23600000 | 44.5 | 5120 | 64 qam | 13 |
on 24-10-2022 23:37
Those stats are very good except for on upstream channel on 32 QAM when it should be 64 QAM.
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended.
VM will not dispatch any technicians while an area fault exists.
If no faults found:
Call Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
on 25-10-2022 21:25
Thanks, Tudor.
The upstream channel you referred to (and I posted twice about) seems to change between 32 qam and 64 qam when I refresh the page.
I am happy for a VM staff member to get to the thread and hopefully just arrange for a replacement Hub to be shipped.
on 25-10-2022 23:21
VM will get to your post, but hubs are not just sent out, they need a technician’s visit.
on 26-10-2022 20:17
Oh now that is a shame! It would be impossible to schedule an engineer visit to coincide with the intermittent situation whereby the Hub completely stops responding to pings, network traffic, port 80 etc. and so one would assume the most cost-efficient solution for Virgin Media and time-efficient, convenient solution for me as the paying customer would be to ship a replacement hub. I only use it in modem mode so another Hub 3 would be fine, I don't need an upgrade. Fingers crossed for some common sense.
