rmehta267
  • 13
Message 1 of 23
Hub 3 does not connect to wires coming out of the wall
The person who lived in my flat before me also used Virgin, and thus there are 2 wires coming out of the wall.
These wires, if I am correct, are coaxial ones, with a c. 5mm needle-like point at the outside end.
These needle-like wires, however, are slightly (perhaps by only 3 or 4mm) too short to connect tightly to the Hub. I am therefore left with a flashing green light, which apparently denotes a "loose connection".
I am struggling to see how I am supposed to rectify things.
Additionally, the Hub itself came with a white coaxial wire, which I have not been able to use. This is because, whilst one end of it fits very tightly and snugly to the Hub (in contrast with the wires I allude to above, which were already coming out of the wall), the other end does not connect to the wires coming out of the wall.
As always, Virgin's online support has been truly and utterly useless.
-tony-
  • 16.94K
  • 1.32K
  • 4.01K
Message 2 of 23
Re: Hub 3 does not connect to wires coming out of the wall
post some photos - in the mean time look for another wire or wall box - VM would normally only have 1 coax wire - 2 sounds like a sky shotgun cable - what dia are the wires and if you trace them back are they a twin wire
____________________
Tony
rmehta267
  • 13
Message 3 of 23
Thanks very much for the quick response. Think the diameter is around 6mm and yes it's a twin wire.
WhatsApp Image 2020-10-26 at 14.26.09 (2).jpegWhatsApp Image 2020-10-26 at 14.26.09 (1).jpegWhatsApp Image 2020-10-26 at 14.26.09.jpeg
-tony-
  • 16.94K
  • 1.32K
  • 4.01K
Message 4 of 23
thats sky cable - so either the previous tennent was wrong - why should he be or there is another box or cable somewhere in the flat - you are really looking for a wall box bus sometime they are removed and just the cable left - VM cable is thicker than that 10mm ish and single
there has certainly been VM there before - if not then quick start would not have been possible
difficult with flats but best start point is outside - look for the external wall box and follow the cable from it inside
where did the white cable come from and more interestingly the 6db attenuator - i was not aware sky used them - they certainly look like VM parts
Tony
rmehta267
  • 13
Message 5 of 23
Thanks Tony. So I just spoke with the previous owner, and I can confirm that the white wire you see is the Virgin wifi one.
He said the Virgin engineer added the attenuator in his case.
It doesn't connect firmly to the Hub even without the attenuator.
-tony-
  • 16.94K
  • 1.32K
  • 4.01K
Message 6 of 23
i obviously cannot dispute what you say but there is something badly wrong - no question the twin wires are not VM installed - they are Sky - how and why they work is interesting in the least - if a VM tech has used them and added the cable and attenuator then he needs his hands smacked imo as under no circumstances is Sky coax good enough for VM
but lets go back - the arrenuator is always a bit delicate on the back of the hub - i would remove it and put it between the Sky cable and the white cable - then connect the white cable to the hub - that should be ok
assuming the previous owner is telling it all then your connection should work - lets see if it does
BUT and its a big but you need a tech who is going to do the thing correctly and not make do - so will flag the thread and lets get something booked
post back if it works when you connect it all up
Tony
rmehta267
  • 13
Message 7 of 23
Thanks for the suggestion.
It sadly doesn't work even with the attenuator repositioned.
-tony-
  • 16.94K
  • 1.32K
  • 4.01K
Message 8 of 23
i assume you get a green flashing light - if so no great surprise - no way should it be running down sky coax if it indeed is - wait for VM to get to the thread they will book a tech or ring and book one
Tony
rmehta267
  • 13
Message 9 of 23
Correct -- flashing green light.
Will do, thanks.
Corey_C
  • 3.98K
  • 220
  • 335
Message 10 of 23
Hi rmehta267
Thanks for your post and welcome to the Community Forums
I've got a tech visit booked for you to help with your setup on Saturday, Date: 31/10/20, 12-4PM. You can view or reschedule this from your online account with this link
Corey C
