Lrutter
Hub 3 WiFi issue
just moved into our property today and connected the hub 3 up as instructions say. The green wifi light is on but the bottom light is flashing green. The little stick in one end of the white cable we received in the box is bent. And desperately needing the WiFi running as have a small child and work from home. Please can someone advise on how to fix this or help me book an engineer if one is needed?
thanks
Z92
  • 2K
  • 166
  • 307
Super solver
Re: Hub 3 WiFi issue
You can try and bend the pin back if you are desperate, but if it breaks you are going to need an engineer, and those things are fragile.
Customer services should be able to send you a new cable though.
