on 07-12-2022 12:13
Hello,
My hub 3 is on with constant orange light, wifi is still workable but the connection is fluctuating.
How can I order a replacement hub?
Since I am currently WFH, I cannot return the current one without having the replacement router first.
Thank you.
on 09-12-2022 16:27
Hi kazuive, thanks for the message and welcome to the forums.
I am sorry to hear that you are having issues with the WiFi connection.
I have looked into this and there are no area outages and everything is showing as green.
Can you confirm if you are still having issues since posting?
Kind regards, Chris.
