Lozzybab
Hub 3.0 wall socket issue
I have just moved into a home that has VM already installed to the property. I recieved a new hub 3.0 in the post today but have come unstuck with plugging the new cable into the VM wall socket.
There is an existing wall socket which is plain (no logo) has two rectangle covers and has an existing cable 'CABLECON 3.9'.
The installation kit instructs to use the spanner to remove the existing cable but isnt compatible. Also from eye i don't believe the new wall adapter wont fit into the socket if the cable was removed.
Any ideas?
Z92
  • 2.47K
  • 203
  • 392
Problem sorter
Re: Hub 3.0 wall socket issue
Can you post pictures of what you have found?
