MartinFS
Message 1 of 5
Hub 3.0 shows ethernet connection toIpad
My Hub 3.0 lists connected devices as including ethernet  connection to various devices including my iPhone and iPad.and Sonos speakers. Does anyone know why and howit canbe fixed please.  Is this the reason why my samsung wireless speakers only work intermitenly.
And one final techy question when wifi selects channels auto matically does that change for all connected devices or can different devices be on different channels.
Thanks in anticipation
Z92
  • 2.59K
  • 208
  • 415
Trouble shooter
Message 2 of 5
Re: Hub 3.0 shows ethernet connection toIpad
Your speakers probably work intermittently because the WiFi from the hub 3 is crap. If you want decent quality WiFi you need to invest in a decent quality WiFi router. The provided router is build down to a price and considered basic in all forms.
jem101
  • 2.38K
  • 279
  • 1.09K
Message 3 of 5
@MartinFS do you happen to have any wifi extenders by any chance, especially the Powerline connected ones? Different devices can't be on different channels, no - the Hub chooses the channel it thinks is the best and only broadcasts on that one, all client devices move to that channel.
MartinFS
Message 4 of 5
Thanks for the helpful points, good to know I do not have to worry about channel selection.  I do have an ethernet over power extension by Devolo.  The wifi repeater must be delivering a stronger signal than the base station.  The old pantomine joke the wifi is behind you.
jem101
  • 2.38K
  • 279
  • 1.09K
Message 5 of 5
As far as the Hub is concerned, the access point and, crucially, any WiFi device which is ‘associated’ with it are connected over Ethernet, which is why you can often see phones and tablets apparently ‘wired’ in to the Hub.
There is a common misconception about WiFi where people usually think that if you have two access points broadcasting the same SSID, then if you connect a device to the WiFi it will ‘seamlessly’ hop between the access points depending which one has the strongest signal as you move around - this isn’t actually the case! Once connected a device will ‘stick’ to that access point even if a stronger signal is available until the signal level drops below a certain threshold at which point the device looks for a better signal and associates with that one. Mesh WiFi systems and properly managed access points talk among themselves and work out if a particular device would be better off on a different access point. If so, then they send a ‘disassociate message’ to the device which disconnects from the current access point and reconnects to the better one.
Your booster may not have a stronger signal than the Hub, it’s just that it is the one your iPad first connected to and it will stay connected until the signal drops below a critical value.
