Suze100
Hub 3.0 settings
Hi, I reset my hub 3.0 today because the WiFi has been intermittent.   I now only have the one network whereas previously I 2g and 5G but I can’t remember how I can fix this.   I know how to login to the hub so if anyone can tell me what to do next that would be great - thanks
  • 26.46K
  • 2.7K
  • 4.9K
Re: Hub 3.0 settings
Here you go...
___________________
Type in  http://192.168.0.1  into your web browser’s url box and login with settings password on the Hub's base sticker (or your own if you changed it). Then in Advanced>wireless>smart wifi - tick the disable “channel optimisation” box and save settings.  Then, go to advanced>wireless>security, rename the 2.4 & 5 GHz network ssid's.  Just change 'em to whatever you like and something that will differentiate them (e.g - xxxxx2 & xxxxx5) -- use the same password if you like,  Then, apply settings and restart the Hub.  Your 2 wifi networks will now be clearly separated - and you can then select the network you want to connect to individually from the "available networks" list on each device.
Suze100
Thank you so much for your help - much appreciated!
