SaitenMar
  • 19
Hub 3.0 issue - Internet/Wireless working - Yellow base light - No green lights.
Hi folks,
Just had a Hub 3.0 delivered and I set it up but I'm a little unclear on an issue. Tried doing some googling but couldn't find a real answer to my question. Basically, it starts up and goes through the process of connecting, showing green lights at the base, internet, and wireless (no phone is connected) and it appears like everything is okay when I check my wired and wireless connections. But eventually, the base light goes yellow and the two green lights turn off entirely.
Is this normal behavior for Hub 3.0, or is it a sign of something not working right?
Thanks.
  • 1.94K
  • 125
  • 448
Super solver
Re: Hub 3.0 issue - Internet/Wireless working - Yellow base light - No green lights.
We have a HUB 3 - once started and operating normally there is just a yellowish white bar lit at front.
All other front panel lights are off.
SaitenMar
  • 19
That's good to read. Everything seems to be working fine to be fair.
  • 6.82K
  • 593
  • 1.79K
Old component LED most likely has gone yellow over time.  It should be white when new.  If it's working leave well alone  🙂
