JP3119
Just joined
Hub 3.0 internet light and base light flashes
Wifi has been playing up tonight.
Green wifi symbol and baselight constant with green internet symbol flashing.
Then
Green WiFi symbol constant with green baselight flashing.
Does each for about 2 minutes each and switches between the two constantly. I have tried resetting the box and have turned it off and on. The connection is plugged in tight.
Anybody help?
  • 14.2K
  • 1.52K
  • 3.09K
Re: Hub 3.0 internet light and base light flashes
Check the service status via the link above.
If no issues are reported then this may signify the hub has got stuck in an update loop. In any case you should contact faults to get it looked at.
Click to learn more about VIP
Use Kudos to say thanks
