Perostek
  • 20
Message 1 of 21
How long for speed increase to Gig1?
I upgraded from the 500mb service to Gig1 today. Installed the new Hub 4 about 7 hours ago and the internet works fine.
My upload speed has moved to about 50mb when I check on speedtest but the download speed is exactly the same at about 500mb. Do you know how long it takes for the speed increase to come through on the download?
My service package has changed to Gig1 on my account page and I received a text telling me a signal was sent to my home. I'm testing on a pc with cat 6 ethernet.
Thanks in advance
Anonymous
Not applicable
Message 2 of 21
Re: How long for speed increase to Gig1?
@Perostek wrote:
Thanks in advance
If your upload speed has changed then so would your download.
What does this site show?
Perostek
  • 20
Message 3 of 21
Thanks for the swift reply Carl. I'm in modem mode at the moment with an Asus router (on the gigabit port) so will change it back and revert tomorrow morning. My partner is in the middle of a Netflix thriller and won't let me interfere with that, even for a moment.
  • 16.27K
  • 711
  • 1.6K
Message 4 of 21
Maybe you have QoS set to limit your download speed on Asus router?
Perostek
  • 20
Message 5 of 21
No limits on download speed on QoS or otherwise. It's on the same settings as it was with the superhub 3.
Perostek
  • 20
Message 6 of 21
Ok, so I tested on the Samknows site and got 1063/925 so it has been actuated.
I went into router mode for this and tested the speeds on wired connections which corresponded with Samknows. However, even though I have internet there are quite a few glitches - the speeds fluctuate wildly during the day and often I can't get into the router via 192.168.0.1, then suddenly I can.
I've tried lots of different ways to enable modem mode with my Asus RT AC66U B1 router but it isn't having it, including rebooting in the right order etc. The same one worked perfectly with the Hub3. There is very little in the way of information on the Virgin site about this - it just tells you how to put it into modem mode but nothing else. Bizarrely it did work, but at reduced speeds i.e. 500mb rather than 1000mb. It showed the wan port on red even though it was obviously connected and able to access the internet. I'll research futher. I should stress that the problems are with download speed, not upload which is solid at 50.
Looks like I'm stuck with the Hub4 for the moment. Early observations are that it's ok but wifi drops off quickly - much more quickly than the Asus. I'm concerned about the wild variance in speed but that may be early days. I'll just have to monitor.
Anonymous
Not applicable
Message 7 of 21
Let's have a look at the stats:
Could you access your router using http://192.168.0.1/ or http://192.168.100.1 for modem mode . You shouldn't need log in, select the 'Check Router Status' option and paste your 'Downstream', 'Upstream', and 'Network Log' tabs? Please copy/paste this data as text, split between multiple posts (Sometimes you have to click 'Post' twice due to an error message).
Could you please create a BQM (Broadband Quality Monitor) here, and post the live link?
Perostek
  • 20
Message 8 of 21
Thanks for your help with this. Here is the downstream
3.0 Downstream channels
304027500006.69999740.366287QAM25630
11387500002.09999837.636276QAM2561
21467500003.50000038.605377QAM2562
31547500003.79999938.605377QAM2563
41627500003.50000038.983261QAM2564
51707500003.29999938.605377QAM2565
61787500003.50000038.983261QAM2566
71867500003.59999838.983261QAM2567
81947500004.00000038.983261QAM2568
92027500004.00000038.983261QAM2569
102107500004.50000040.366287QAM25610
112187500004.50000040.366287QAM25611
122267500004.90000240.366287QAM25612
132347500004.69999738.983261QAM25613
142427500005.30000340.366287QAM25614
152507500005.09999838.983261QAM25615
162587500005.50000040.946209QAM25616
172667500005.30000340.366287QAM25617
182747500005.80000340.946209QAM25618
192827500005.90000240.366287QAM25619
202907500006.40000240.366287QAM25620
212987500006.40000240.366287QAM25621
223067500006.40000240.366287QAM25622
233147500006.00000040.366287QAM25623
243227500006.40000240.366287QAM25624
253307500006.30000340.366287QAM25625
263707500006.40000240.366287QAM25626
273787500006.19999740.366287QAM25627
283867500006.59999840.366287QAM25628
293947500006.50000040.366287QAM25629
314107500006.50000040.946209QAM25631
30Locked000
1Locked31404979900
2Locked31643269300
3Locked31178295400
4Locked22102595700
5Locked22075744200
6Locked22050212700
7Locked22072856900
8Locked9279356900
9Locked9267125300
10Locked9255236400
11Locked9280676100
12Locked9195687800
13Locked9190446900
14Locked8868241900
15Locked9173734600
16Locked7570774600
17Locked8930903600
18Locked8929869100
19Locked8882918900
20Locked8878543200
21Locked8938432500
22Locked8906155500
23Locked8919393700
24Locked14373247200
25Locked14695664600
26Locked14716848000
27Locked14720835100
28Locked14896454700
29Locked15082468700
31Locked24537854460
3.1 Downstream channelsChannel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
159864K1680QAM4096424
3.1 Downstream channelsChannel ID Lock Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
159Locked 8.297937512090
Perostek
  • 20
Message 9 of 21
Upstream
3.0 Upstream channels
15370000045.0205995120 KSym/sec64QAM5
23260000044.5205995120 KSym/sec64QAM8
33940000044.5205995120 KSym/sec64QAM7
44620000045.0205995120 KSym/sec64QAM6
1US_TYPE_STDMA0000
2US_TYPE_STDMA0000
3US_TYPE_STDMA0000
4US_TYPE_STDMA0000
Perostek
  • 20
Message 10 of 21
Network log
Thu 01/01/1970 00:01:233No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 07/11/2020 12:32:155MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 07/11/2020 12:33:026CM-STATUS message sent. Event Type Code: 3; Chan ID: N/A; DSID: 300880; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 07/11/2020 12:35:375MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 07/11/2020 12:35:526SW Download INIT - Via Config file a69834ncxv9873254k;fg87ds
Sat 07/11/2020 12:37:056SW download Successful - Via Config file
Sat 07/11/2020 12:39:385MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 07/11/2020 13:08:104DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 07/11/2020 13:08:106DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 07/11/2020 14:05:084DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 07/11/2020 14:05:086DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt076-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 07/11/2020 14:57:015MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 07/11/2020 15:10:436CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sat 07/11/2020 17:58:115MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 08/11/2020 13:15:266CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
