on 23-03-2023 19:23
Hi I have a question about engineer setting new cable line in to my flat just wondering how long does it take to finish it?? Thank you
on 23-03-2023 19:39
@Pisaret wrote:Hi I have a question about engineer setting new cable line in to my flat just wondering how long does it take to finish it?? Thank you
Do you mean the time the VM tech will be at your flat doing the work to install your equipment?
Or do you mean the time it might take VM to install a cable from the street to your flat?
The first answer should be quite quick. The second answer could also be quite quick but could also be a very long time (it all depends on your individual circumstances)
Have you ordered VM and are waiting for the installation or just thinking about ordering VM?
on 24-03-2023 00:22
I just ordered and have an appointment on this Saturday but I finish work at 3pm so I just a bit worry about the time
on 27-03-2023 08:47
Hi Pisaret,
We're sorry to hear the appointment may not be convenient for you due to work. If you've already registered for My VM then you can look at rescheduling the appointment via there. Just click here then once you log in scroll down to Orders & appointments then click on View your orders. From here you can choose a new date more suitable for you.
Please ensure you are available for the full timeslot that you book as the engineer can come any time during that slot and if you miss it, there would be a £25 charge.
Keep us posted on how things go.
Many thanks,
