  • 8
Home Distribution Unit
Does anyone know where I can get one of these units from?
Also, will my set up work without one?
  • 19
  • 5
Re: Home Distribution Unit
hi there unless the signal to your equipment is out of spec you don't need one.
  • 13
You should not need a HDU unless your signal is low
Hope this helps
Virginmedia HDU is only used to increase signal levels for two or more devices. They dont give you an option to watch TV in every rooms.
  • 28
  • 5
  • 8
hi
a HDU will only be fitted on install/service if the engineer deems the downstream or upstream signals would be out of spec if a conventional splitter was used.
it offers no form of boost its a powered splitter which doesn't suffer from signal loss like a non powered splitter.
I am a Virgin Media Field Technician working from home. All and any advice given is based on my experience in the field or my personal experiences with my own set up at home. If my answer was helpful to you please Mark as helpful or consider leaving the post some Kudos.
  • 8
Thanks for all your replies, all coupled up and I am now trying to connect.
