on 06-06-2022 15:01
So my Hub 3.0 has completely stopped working. Can't be switched on, no lights, nothing.
I got through to VM on the phone and they said the best they could do was send an engineer on the 15th June. This is 9 days without internet and I rely on a stable internet connection for work. So I'm in pretty desperate need here.
Is there anything that can be done more urgently? It's really just the Hub that needs replacing - surely this can be posted to me rather than having to wait 9 days for a technician to visit? I can send back the broken one if need be.
Any help appreciated.
on 07-06-2022 09:56
Hello mn55,
Thanks for your post.
Sorry to hear about the issue with your Hub and the wait time.
I can look into this for you.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
